Old 01-23-2020, 09:49 AM   #1
gt7877
Drives: turbo frs
Question shifting turbo kit from MT to auto
Dear
I need to shift my turbo kit and every parts from
2014 FRS to 2016 auto FRS
What I have to do first
My plan to remove all turbo parts
With ecu
To new car
But the issue is at the tune
I have bin file i tuned it by HRI
Onle tune
Any recommendations
Any ideas
What I have and what I should do
Thnx in advance 👍
gt7877 is offline   Reply With Quote
Old 01-23-2020, 10:41 AM   #2
86TOYO2k17
Drives: 2017 toyota 86
You will not be able to switch the ECU from the 2014 MT to the 2016 AT if that is what you are asking. You will need to get a new ecutek license, and a new tune specific to the 2016 AT ROM. Have to work with your tuner on getting that setup.
The physical turbo kit itself should be relatively easy to switch over.
Old 01-23-2020, 10:44 AM   #3
tomm.brz
Drives: brz 2017 hksv2
Maybe if you switch ecu and do the marry procedure and before starting the engine, you flash an AT tune, could work
Steve will probably know the answer
The Following User Says Thank You to tomm.brz For This Useful Post:
gt7877 (01-23-2020)
Old 01-23-2020, 01:19 PM   #4
gt7877
Drives: turbo frs
Steve is a great man
He hepe alot
Am waiting his reply
Thnx to all
Old 01-23-2020, 06:04 PM   #5
86TOYO2k17
You can physically swap ECUs but you will still need a new 2016 auto rom tune. So i do not see the point in swapping ecu it is a tedious process outlined here http://www.ft86club.com/forums/showthread.php?t=102810
But again you will lose your tune, because you will need a entirely different rom a tuner will need to setup as if its a brand new tune file.
I am not 100% what will happen to the ecutek license it may be possible to keep it in this scenario. But idk if it is worth the headache and potential issues over a 300$ license. Note you will need tactrix cable which is about 180$, so if your lucky you save 120$.
Old 01-23-2020, 06:10 PM   #6
tomm.brz
if he already has the old ecu that has the paid license in it, why should he throw away?
he can ask his tuner to set up an auto Rom based on the old manual tune
it takes few time
Also i don t know where you saw 200, a license costs at least 300 dollars, most of time ever more
Old 01-23-2020, 06:26 PM   #7
86TOYO2k17
it takes few time
Huh? Reread post more clearly.
Its possible. But a tedious process to save roughly 120$, if its even possible to save license. Unless it can somehow be done without a tactrix cable but I doubt it.
Old 01-23-2020, 07:36 PM   #8
tomm.brz
Sorry, read wrong
Why would he need tactrix? he just need his ecutek kit and marry the old ecu to new car before that.. does he need tactrix for making this? I thought it is just about bridging 2 pin in the obd port
Old 01-23-2020, 07:50 PM   #9
86TOYO2k17
Sorry, read wrong
Based on the link i posted where Steve outlined the procedure. Step 2 You have to get the vin id onto ecu. Although he says you may not have to but idk don’t have the time or desire to research this more.
@steve99 would be the best bet to answer all this.
Old 01-23-2020, 09:40 PM   #10
steve99
Originally Posted by gt7877 View Post
Dear
With ecu
To new car
Onle tune
Any recommendations
Any ideas
Thnx in advance 👍
The ecu in all cars is same hardware
But different models years and auto or manual requires different calibratio\tune in ecu to work.
Are both cars auto ? And if both from say USA then a 2014 auto ecu will straight swap into a 2016 auto same country no problem
Just use the ECU resync proceedure i posted up. No need to chage vin numbers
If one is auto one manual the you can swap ecu but you will need to reflash with a compatable tune to suit new transmisdion type, auto and manual tunes not compatable. You will be able to preserve your ecutek licience but you will need new tune
gt7877 (01-25-2020)
Jerky Shifting with Auto trans? coolguy1o1 Engine, Exhaust, Transmission 6 07-07-2019 04:11 PM
Noise when manually shifting auto Impureclient Issues | Warranty | Recalls / TSB 5 02-13-2018 04:49 PM
auto shifting question. VoltsFRS2013 Engine, Exhaust, Transmission 5 09-02-2017 09:13 PM
Auto Shifting in Manual Mode phantasticity Engine, Exhaust, Transmission 22 06-16-2016 09:56 PM
FR-S turbo auto already sold GTA wbradley CANADA 11 11-13-2012 07:58 PM
