Old 06-14-2016, 04:07 PM   #1
phantasticity
Ricer
Auto Shifting in Manual Mode
So I just received the lovely engine check light on my A/T FR-S, and whenever I'm in manual mode, it's auto shifting at around 7,100 rpm. Anybody know the reason why or how to fix it?
Thank You,
phantasticity is offline   Reply With Quote
Old 06-14-2016, 04:30 PM   #2
FirestormFRS
CEL disables a lot of stuff, may include flappy paddles.
FirestormFRS is offline   Reply With Quote
Old 06-14-2016, 04:39 PM   #3
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
You need to find out what is actually causing your CEL first.....
Either get your own code reader or see if your local auto parts shop will let you use theirs. Once you know what the code is it will be a lot easier to fix the problem.....
Just to eliminate the possibility, are you sure that you did not set your rev limiter at 7,100? That might force it to upshift on you even with 100% throttle in manual mode. Probably not a good idea to keep revving it up to 7,100 while you have a CEL as well.....
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
mixtape (06-16-2016)
Old 06-14-2016, 05:00 PM   #4
phantasticity
Ricer
I reset the battery last night, and the CEL was gone, but after driving for about 15 miles this morning it came back again. It's just really weird because my car is an A/T but when I'm in Manual it reacts like its in A/T and just auto shifts instead.
Old 06-14-2016, 05:05 PM   #5
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Anytime you disconnect the battery it will probably clear those CEL codes. When the light shows back up again after it was cleared you have some type of problem.
You and us need to know what code you have so we can try to help. A CEL can pop up from so many different things ranging from your gas cap not being tightened to a rod punching a nice hole in your block. Once you have the code google it as someone has most likely ran into it before and you will probably find out if it is something trivial or something you should be concerned about
EDIT: To somewhat amend my earlier post: I have an A/T as well. Even if you set the rev limiter it will just bounce off of it and jerk the car in manual mode so it should not be auto shifting.
Tcoat (06-16-2016)
Old 06-14-2016, 06:22 PM   #6
brianhj
Drives: 2017 Camaro 1SS
Go to autozone, they will tell you the code for free. Then tell us the code. Or google the code.
brianhj is offline   Reply With Quote
Old 06-14-2016, 06:53 PM   #7
phantasticity
Ricer
I just bought an OBDII scanner, and the code is P0171
Old 06-14-2016, 06:59 PM   #8
phantasticity
Ricer
Code is P0171, also checked my intakes, everything is very tight, so nothing is loosening.
Old 06-14-2016, 06:59 PM   #9
gramicci101
Off Topic
P0171 is running lean. Do you have any mods on your car such as header, tune, or intake?
Old 06-14-2016, 08:13 PM   #10
phantasticity
Ricer
I fixed it, one of the tiny hose from my intake was leaking I didn't even see it lol.
Thanks for all the helps guys.
The Following User Says Thank You to phantasticity For This Useful Post:
Tectoniic (06-15-2016)
Old 06-16-2016, 02:37 AM   #11
lizbrayan
Drives: '15 Scion Frs Steel
Not to rob the thread but i also have a a/t and when im in manual mode and have the vsc sport on and hit heavy traffic i get a code(dont remeber which one) but its for the cam shaft positioning sensor or something along those lines
Sent from my SGH-T999N using Tapatalk
lizbrayan is offline   Reply With Quote
Old 06-16-2016, 07:16 AM   #12
Cole
Not a troll
Cole's Avatar
Time for a part out
Old 06-16-2016, 08:39 AM   #13
Teseo
Drives: frs
Originally Posted by Cole View Post
Time for a part out
Dibs
Old 06-16-2016, 08:45 AM   #14
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Originally Posted by Teseo View Post
Dibs
On the tires.
The Twins make me smile
Shifting with a manual... Jen Scion FR-S / Toyota 86 GT86 General Forum 110 04-22-2014 10:46 PM
is it possible to rejigger the auto manual mode shifter to flip gear up/down? chickdigger802 BRZ First-Gen (2012+) — General Topics 14 10-18-2013 08:17 PM
A Week of A/T Manual Shifting Mode Ocala FR-S Scion FR-S / Toyota 86 GT86 General Forum 98 05-15-2013 02:35 AM
More MPG in manual mode (AT) aceangel BRZ First-Gen (2012+) — General Topics 11 03-27-2013 01:12 PM
hard shifting in sport mode AT sofrsnsokleen Issues | Warranty | Recalls / TSB 11 12-12-2012 11:13 AM
