Old 01-22-2020, 10:49 PM   #1
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Throttle body coolant flow direction
I searched around and could not find an answer other than "it doesn't matter". But I'm curious, for the two coolant ports at the front of the TB, does coolant come out the top or the bottom outlet?
N_Raged is offline   Reply With Quote
Old 01-22-2020, 11:03 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I have no idea, but if you undo the hose, pull the fuel pump fuse, and turn the car over, the end spewing water out will tell you where the inlet is.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
N_Raged (01-26-2020)
Old 01-26-2020, 11:26 AM   #3
N_Raged
Thanks for the idea! I can now confirm that the bottom port is the where the coolant comes out.
The Following 6 Users Say Thank You to N_Raged For This Useful Post:
bcj (01-26-2020), Bonburner (06-15-2020), Hiko (01-27-2020), Limitless_BRZ (02-24-2021), mrjj (04-06-2021), YamahaR86 (01-27-2020)
Coolant Flow Direction? HawaiianMike Engine, Exhaust, Transmission 26 04-11-2024 12:16 AM
coolant to throttle body hose notout86 Engine, Exhaust, Transmission 11 06-14-2018 10:49 PM
throttle body coolant flow direction mhiscott Forced Induction 3 07-12-2016 04:24 PM
throttle body coolant choi0706 Engine, Exhaust, Transmission 21 10-18-2014 04:31 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
