Drives: t
throttle body coolant
anyone bypass this?
Drives: toyota mr2/ Toyota GT86
I'd agree that this is a good idea as unless you're in the Antarctic there's no need to heat the throttle body motor
Because compromise ®
Drives: Red Herring
Whilst I agree with the sentiment the region just downwind of the butterfly valve experiences low pressure drops which can lead to icing even in temperatures above freezing temperature of the ambient air. Given that the throttle body is quite short I am suggesting the amout of heating this does to the ingoing air is quite small.
Drives: '13 BRZ Limited, '95 BMW M3
I was going to post the same thing. Not many people believe this
Drives: 2015 Series.Blue
Not going to make any more power and it's there to stop icing (which can happen at temps as high as 70F).
It depends on a lot of factors (humidity, pressure, etc). |
Drives: Red Herring
While I knew of the phenomena I didn't realise it could be as high as that.
Isn't it called the venturi effect?
Go ahead and by pass that shit. The multitudes of automotive engineers that design stuff like that have no clue wtf they're doing.
Drives: ft86
#10 |
Drives: 2013 Firestorm FRS
so let me get this straight...
remove the bypass, and get ice in throttle body. The more ice in the throttle body, the colder the air charge. The cooler the air charge, the more power. The more power, the less chance of being smoked by prius. win. Obviously jk |
#11 |
Drives: Scion FR-S
#12 |
not playing cards
Then you stall out and crash.
#13 |
The Thread Lurker
Drives: '14 BRZ, '17 GTI, MT09
#14 |
not playing cards
| Cusco Throttle Body? | track_warrior | Engine, Exhaust, Transmission | 66 | 06-28-2016 06:28 PM |
| FA20Club Throttle Body | JDogg | Engine, Exhaust, Transmission | 22 | 12-01-2014 04:00 AM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
