Issues with white smoke after spark plug change
Hello all, sorry about the title, I ended up figuring out the smoke.
I just changed the spark plugs on my 13 FRS at 88k miles. I recently went FI and have been having misfires over about 5 psi, so I figured I would change them out. I should note that I am on basemap tune for the SBD 500x kit, and have the car has been running rich since I re flashed (with Openflash through Shiv). After telling shiv that I had misfires, I sent him some logs and he said he had difficulty seeing why it was happening. Everything went well, but I did notice that the DI ECU was missing the bolt on the bottom. From what I read, that bolt is required for grounding purposes. I replaced the bolt and started it up. So far, I have gotten the P0300 code multiple times when getting over 5 psi boost, and the P0303 and P0301 codes off along with it. Any help is greatly appreciated. Last edited by Japanese_Carbon; 01-22-2020 at 06:02 PM. |
JDM Vaping Stance Nation
Drives: 2013 White
How does your LTFT and STFT look? If it's running rich I'd imagine you have a leak somewhere.
Clueless
| Helpful DIY Spark plug change video | DTMdreaming | Engine, Exhaust, Transmission | 13 | 10-17-2020 08:55 PM |
| Spark plug change - dealership price? | wparsons | CANADA | 47 | 05-08-2019 06:48 AM |
| Spark Plug Options? | BRZach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 27 | 08-18-2017 12:14 AM |
| P0351 bad spark plug... | Jaden | Engine, Exhaust, Transmission | 3 | 01-02-2016 10:19 AM |
| Spark plug question | Wilsonk227 | BRZ First-Gen (2012+) — General Topics | 19 | 07-03-2013 12:57 AM |
