Old 01-20-2020, 07:12 PM   #1
Leviathan83
Leviathan83's Avatar
Drives: GT86
Camshafts upgrade
Hi to everyone.
I'm planning to modify FA20 engine with forged internals, new valves, new valve springs and install the HKS Supercharger V2.
In these days I'm considering also the possibility to upgrade also camshafts with something more "spicy".
However someone says that this is a mod that has some issues, because the benefits concern mid and high-range power with loss in low-range... is that correct?
Except for HKS Cams (that require hks stroker kit) I found only Piper Cams as alternative, in the configuration:
- Fast Road SUBFA20BP270 262° 266°
- Ultimate Road SUBFA20BP285 272° 266°
I wrote to Piper Cams about installation and they said the 270 fast road camshaft should allow to install without the need for any changes or modifications; the 285 will require valve train component modification, so valve springs and it is possible you may need to shim in case of a clearance issue.
In pratical, what kind of work it's need to install the 285 cams to avoid clearance issue?
Could be relevant the difference between 270 and 285 in terms of performance?
And is it a modification that makes HKS supercharger (and other upgrades on internals component and valvetrain I'm planning to do) more efficient and usable?
Sorry for my question (and my English), I'm not an expert!
I know that there are several posts about camshafts; in these days I read lots of them (especially about Piper Cams) but I didn't find informations about the questions I have.
Thanks to all of you for answering!
Leviathan83 is offline   Reply With Quote
Old 01-22-2020, 03:20 AM   #2
bobel
Drives: GT86
I’m currently building my own engine that is also running a HKS V2 Supercharger
I am not upgrading the valves but I am using GSC beehive springs so somewhat similar
From the research I’ve done the OEM head and camshafts are actually very good and flow quiet well, I think if you are going with new valves a +1mm oversize on the exhaust valves and some light porting is probably all you need to extract the maximum out of a HKS V2
I think the lack of aftermarket cams probably says a lot about the ultimate need for them when not chasing huge numbers, but of course that’s just my opinion.
bobel is offline   Reply With Quote
Old 01-22-2020, 10:05 AM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
The lack of aftermarket options may also be due to the stock camshaft design being pretty good (fat lobes and near infinite adjustability with ACVS). Before ACVS a higher lift and longer duration camshaft would be an easy HP gain. Not so much now. Link to my post from 5 years ago.
https://www.ft86club.com/forums/show...4&postcount=24
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-22-2020, 11:34 AM   #4
Lantanafrs2
Drives: 2013 frs red
I think someone is selling piper cams in the classifieds
Old 01-22-2020, 02:48 PM   #5
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
https://www.ft86club.com/forums/showthread.php?t=133380
Dzmitry is offline   Reply With Quote
Old 01-22-2020, 06:02 PM   #6
Leviathan83
Drives: GT86
Thanks for your reply. I considered the possibility to go with +1 valves, but I think this job is very expensive (do you know approssimately how much could be?)... And you have to find someone reliable to do it. By now, I didn't find anyone to do the job...
Is possible to enlarge without damaging heads?
This is very interesting. I read that article some years ago, but I forgot it. Thanks. I thought that also the aftermarket cams could be as flexible as stock ones...
In terms of performance, maybe camshafts don't make this huge difference. Seeing HKS graphs with their camshafts, the gain is only 10 HP and 12 nm of torque with more displacement and V2... Maybe Piper Cams don't change a lot from HKS.
I don't know if new camshafts and new spring allow to push rpm... even if I heard that HKS compressor is rated for max 7.400 rpm...
Originally Posted by Dzmitry View Post
Thanks for the link. Yes, I saw it, but it's the Rally version...
I found also this article https://dsportmag.com/the-tech/educa...haft-analysis/
and this unofficial data for these Piper Camshafts; unfortunately nothing similar for stock cams... what do you think?
Fast Road
Ultimate Road
Old 01-22-2020, 08:06 PM   #7
86TOYO2k17
Drives: 2017 toyota 86
FBM also makes a cam. Could reach out to them for a full built head. I doubt cams do too much without oversized valves and some port work on the fa20s. But the more boost you make the possibility for cams potentially being more beneficial increases.
http://fullblownmotorsports.com/full...age-1-camshaft
Old 04-10-2020, 03:25 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I am revising this topic on camshafts. The ones from HKS are a mild increase and they cannot offer much improvement. Another topic to be careful with the Piper cams is that they are not of very good build quality. Check attached screenshot.
Old 04-26-2020, 04:13 PM   #9
Leviathan83
Drives: GT86
OMG! Not good... I heard something about bad Piper Cams reliability...
Probably, OEM cams are the best choice... Maybe it's better to invest on valve springs and valves to increase power.
How about valve springs to increase power? Read a lot about dual vs beehive layout... What's better to increase rpm with OEM camshafts?
I heard also that OEM rocket arms are not so strong, and there are no aftermarket upgrade to increase reilability...
Old 04-26-2020, 10:17 PM   #10
solidsnake11
Drives: brz
I read about two brand new motors with broken piper cams. I don't even think either one finished the first race event.
solidsnake11 is offline   Reply With Quote
Old 04-26-2020, 11:56 PM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I heard that Piper revised after the manufacturing process. So, maybe there isn't an issue anymore ...
@CounterSpace Garage did you have any issue with their camshafts?
Old 05-13-2020, 06:01 PM   #12
Fa20Toybaru
FA20ToyBaru
Fa20Toybaru's Avatar
Drives: Manual
I am also building my FA20. I am currently researching cylinder heads. The recommendations on here are pretty good. Going +1 has shown good results. I was looking at the piper and HKS cams. I did not know what the difference was until I asked my tuner. If we were to look at this as an option. We have to consider "LIFT" and "DURATION". This from my understanding is what gives the increase in performance. If anyone has further explanation on this please let me know. I have also heard that the stock cam are reliable and good.
Question: If one uses the HKS cams, are we stuck only using their motor upgrades?
I have also posted a thread that I need help on. It's about transmissions. I do need help on that, at this point . Thanks in advance, good luck on the build
Fa20Toybaru is offline   Reply With Quote
Old 05-13-2020, 06:35 PM   #13
PulsarBeeerz
Drives: JRSC BRZ SOLD
Element Tuning or Full Blown are the guys you want to talk to.
PulsarBeeerz is offline   Reply With Quote
Old 05-13-2020, 06:50 PM   #14
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
You will get further gains by improving your boost add-on (or choice of forced induction) than by swapping internal components of the FA20.
The power difference between the dyno graphs with the HKS stroker+cams will further increase as you raise the the boost up. I cannot speak for HKS's superchargers but Harrop has also been testing HKS's stroker+cam combo on their S/C track project seeing increased results.
Here is a member with the HKS V2 and the HKS kit to read about: https://www.ft86club.com/forums/show....php?p=2097618
camshafts, engine, valve, valvetrain
HKS 2.1 stroker kit & camshafts nikitopo Engine, Exhaust, Transmission 7 03-24-2020 06:51 AM
Just ordered new Camshafts Fonzi Forced Induction 21 02-11-2018 02:31 PM
Piper Camshafts brn12345 Engine, Exhaust, Transmission 107 10-02-2017 10:28 AM
Camshafts and Boost! Dream20b Forced Induction 23 01-16-2016 02:49 PM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 07:35 PM
