Old 04-24-2019, 02:57 AM   #1
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
HKS 2.1 stroker kit & camshafts
I would like your opinion on the improvements of the HKS 2.1 stroker kit and the relevant camshaft:
Notice the 20hp improvement in the middle and high rev ranges. In this graph there aren't any exhaust changes.
How it would compare with a stock engine and a good catless header with a tune? No E85 fuel comparisons please.
Old 04-24-2019, 10:02 AM   #2
86TOYO2k17
Drives: 2017 toyota 86
I dont think the cam used on this dyno is the one that is compatible with stock pistons. I believe the one that is, had very minimal gains mostly in the top end because lift cant be increased with out recessed piston heads for valve clearance, only a little duration and it wasn't worth it. If going all out NA looking for some high peak power and money isn't an issue i am sure it would add a little. I could see it stacking well on top of E85 or at least WMI for that top end. maybe some 210whp NAs could be possible on generous dynos.
Old 04-24-2019, 10:15 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes I agree. I believe most of the gains are from the stroker kit and the camshaft was used to enhance a bit the top end marked with black circle. The engine displacement increase from the stroker is minimal, but the torque increase looks to be substantial.
I checked also some results from a couple good catless headers. The difference is not that large, so I guess the effort and the cost to install the stroker kit is a serious disadvantage. I would say it makes more sense only if someone combines it with FI. There are other stroker kits too, but these are even more complex with a mandatory cylinder bore honing process.
Old 04-24-2019, 10:44 AM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Look at the chart again. That's not horsepower.
Old 04-24-2019, 10:49 AM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I converted kw to hp
Old 04-24-2019, 02:13 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
I will add here that one of the few cars here in the UK that had a blown engine was running a HKS stroker kit that let go shortly after install. HKS admitted manufacturing defect.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-28-2019, 05:49 PM   #7
Hawk77FT
Drives: GTS 86
Very reassuring! Pheww!
Hawk77FT is offline   Reply With Quote
Old 03-24-2020, 06:51 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Any update on this? Did anyone install the HKS 2.1 stroker & camshaft kit lately?
Just ordered new Camshafts Fonzi Forced Induction 21 02-11-2018 02:31 PM
Piper Camshafts brn12345 Engine, Exhaust, Transmission 107 10-02-2017 10:28 AM
Camshafts and Boost! Dream20b Forced Induction 23 01-16-2016 02:49 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 07:35 PM
