| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2015 BRZ
Metallic rattling between 2-5K rpm
Recently bought a brz and it had no sounds for the first few days but after my mate revved it hard on a cold start yesterday its been making these rattling sounds between 2 and 5k rpm, probably at its loudest at 4.5k rpm.
My engine is stock and I just have an aftermarket axle back muffler and exhaust. I can clearly still hear the engine but it just rattles in addition to the normal sound, its not extremely loud. So its not engine knock right? can someone point me in the right direction |
Drives: 2015 Subaru BRZ Limited
I would suggest trying to locate the noise from outside the car, hood up. Even being able to identify if it's coming from engine bay, back of the car, somewhere in the middle will help you narrow down what could be causing it. I wouldn't rule out something metal cracking from quick temperature change, though. Also, I would suggest with anything aftermarket to double-check the installation and make sure an exhaust hanger didn't come loose.
Sent from my SM-N950U using Tapatalk |
Every Subaru I've had or been associated with had a heat shield rattle at some point.
| The Following User Says Thank You to gravitylover For This Useful Post: | p1l0t (01-17-2020) |
Drives: 2014 Subaru BRZ Sterling Silver
Never rev is hard on a cold start. Shame on him for doing that.
Does it do it in neutral? If not I may have a solution for you. I had this too. It was the inside nut of the valve stem that got loose. It was rattling around inside the wheel at around low speeds but then when I got up to faster speeds it dissipated. Annoying bugger of an issue. |
| Tags |
| brz, engine, engine bay, fa20, sound |
| Metallic grind noise | Vtplm | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 04-06-2019 03:05 AM |
| Metallic tink | Butterballz | Engine, Exhaust, Transmission | 12 | 01-28-2019 01:16 AM |
| Metallic Rattling sound past 4k | J-Money | Issues | Warranty | Recalls / TSB | 2 | 05-05-2014 09:59 AM |
| Strange metallic rattle at around 3-4k rpm. | Brett | Issues | Warranty | Recalls / TSB | 17 | 11-08-2013 03:11 PM |
| True Metallic Plasti Dip | BeRZed | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 07-08-2013 02:30 AM |
