Drives: 2017 BRZ with Performance Package
FYI. My 2017 BRZ Throwout Bearing Went Bad
Hi everyone. I wanted to let you guys know that my 2017 BRZ throwout bearing went bad at 24500 miles. I just took it to the dealer this morning and they are replacing it under warranty. I thought Subaru had fixed this issue but either I got the original part from the factory or the revision didn't fix anything. My BRZ was manufactured in Feb 2017.
JDM Vaping Stance Nation
Drives: 2013 White
Might be using the old part number still. The Revision was in April 2017ish.
http://www.ft86club.com/forums/showthread.php?t=117440
Clueless
Ah ok. I knew that early 2017 model year BRZs had the old part but thought that was for those manufactured in Sept 2016 - October 2016.
Drives:
Just sharing my experience.
I just had my throwout bearing done Friday. I specifically asked for the new part. The mechanic noted how difficult and finicky it was too install, compared to the old version. It's only been a few hundred kms. Hopefully I remember to post back here with an update. This is my second bearing. The original seized at 130K. This second started whining at 220K and replaced at 228K (exedy stage 1 clutch may explain the shorter life). Now I have the revised TOB with another new exedy Stg1. Fingers crossed. Sent from my SM-G930W8 using Tapatalk |
Drives:
It's a touch heavier than stock. I prefer it, but not an objective improvement. It's heavier so it can handle like 40% more torque before slipping.
#8 | |
Drives:
I think there's stockpiles of the old part that they will try and pawn off unless you drill down with them... |
Wes
I bought mine in Feb 2017, wonder how long it’ll last
Instagram: @gt86ws
#10 |
Drives: 2020 STI Limited
#11 |
Rust bucket enthusiast
Just to validate this, I use the Exedy stage 1 clutch and I'm turbo with ~330whp and 250wtq - no issues holding
#12 |
Just the tip
Drives: 2017 DGM BRZ
Checking in at 59000kms... no issues with TOB (knock on wood). Picked the car up April 2017...
| Throwout bearing going bad | B-R-Z | Engine, Exhaust, Transmission | 40 | 09-08-2017 09:23 AM |
| Best quality throwout bearing? | smg1138 | Engine, Exhaust, Transmission | 19 | 07-31-2017 07:48 AM |
| Throwout bearing. | bdanisi | Issues | Warranty | Recalls / TSB | 54 | 07-17-2016 06:13 AM |
| Throwout bearing? | RavioliG | Issues | Warranty | Recalls / TSB | 3 | 10-31-2015 01:17 PM |
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 02:17 AM |
