Old 01-10-2020, 02:47 PM   #1
Tek
Drives: 2017 BRZ with Performance Package
FYI. My 2017 BRZ Throwout Bearing Went Bad
Hi everyone. I wanted to let you guys know that my 2017 BRZ throwout bearing went bad at 24500 miles. I just took it to the dealer this morning and they are replacing it under warranty. I thought Subaru had fixed this issue but either I got the original part from the factory or the revision didn't fix anything. My BRZ was manufactured in Feb 2017.
Tek is offline   Reply With Quote
Old 01-10-2020, 03:07 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Might be using the old part number still. The Revision was in April 2017ish.
http://www.ft86club.com/forums/showthread.php?t=117440
Clueless
YamahaR86 is offline   Reply With Quote
Old 01-10-2020, 03:15 PM   #3
Tek
Ah ok. I knew that early 2017 model year BRZs had the old part but thought that was for those manufactured in Sept 2016 - October 2016.
Old 01-13-2020, 10:51 PM   #4
N234
N234's Avatar
Drives:
Just sharing my experience.
I just had my throwout bearing done Friday. I specifically asked for the new part. The mechanic noted how difficult and finicky it was too install, compared to the old version. It's only been a few hundred kms. Hopefully I remember to post back here with an update.
This is my second bearing. The original seized at 130K. This second started whining at 220K and replaced at 228K (exedy stage 1 clutch may explain the shorter life). Now I have the revised TOB with another new exedy Stg1. Fingers crossed.
Sent from my SM-G930W8 using Tapatalk
N234 is offline   Reply With Quote
Old 01-13-2020, 11:16 PM   #5
radroach
Drives: car
@N234 how's the exedy stage 1 clutch? Noticeable difference from stock?
Old 01-13-2020, 11:23 PM   #6
N234
N234's Avatar
Drives:
It's a touch heavier than stock. I prefer it, but not an objective improvement. It's heavier so it can handle like 40% more torque before slipping.
Old 01-13-2020, 11:33 PM   #7
Tek
@N234 Good to know. I'll make sure the dealer uses the new part as well. Thanks!
Old 01-14-2020, 08:58 AM   #8
N234
N234's Avatar
Drives:
Yeah, you'll want to specify the new TOB part, not just a model year of BRZ/FRS (not related).
I think there's stockpiles of the old part that they will try and pawn off unless you drill down with them...
Old 01-14-2020, 09:59 AM   #9
StraightOuttaCanadaEh
Wes
I bought mine in Feb 2017, wonder how long it’ll last
Instagram: @gt86ws
Old 01-14-2020, 10:19 AM   #10
reebis
reebis's Avatar
Drives: 2020 STI Limited
I picked mine up in January of 2017...hoping I don't see this...
reebis is offline   Reply With Quote
Old 01-14-2020, 10:38 AM   #11
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just to validate this, I use the Exedy stage 1 clutch and I'm turbo with ~330whp and 250wtq - no issues holding
Old 01-14-2020, 11:05 AM   #12
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Checking in at 59000kms... no issues with TOB (knock on wood). Picked the car up April 2017...
wolffbite is offline   Reply With Quote
Throwout bearing going bad B-R-Z Engine, Exhaust, Transmission 40 09-08-2017 09:23 AM
Best quality throwout bearing? smg1138 Engine, Exhaust, Transmission 19 07-31-2017 07:48 AM
Throwout bearing. bdanisi Issues | Warranty | Recalls / TSB 54 07-17-2016 06:13 AM
Throwout bearing? RavioliG Issues | Warranty | Recalls / TSB 3 10-31-2015 01:17 PM
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 02:17 AM
