Drives: 10 series FR-S
Heat is hot on Driver's side, cold on passenger's
Hey y'all,
I've done a lot of searching on these forums and elsewhere, but there doesn't seem to have ever been a fix for this mentioned. I have a 2013 FR-S 10-series (same hvac as BRZ lim) and when the heat is on it only blows hot on the driver's side. A/C still blows cold on both sides, and when switched to heat the passenger side does blow a little warmer than outside temps, but not much. Closing both of the drivers vents makes the passenger center vent a little warm, but the right most vent is almost ice cold. Any thoughts? I don't want to pop the entire dash out unless I know I'll need to, since its a huge pain. |
Going only by your description, it sounds like you have an issue with the passenger side blend door or gate (whatever they call it in an 86). It may be just stuck with something in it or out of sequence. I know some cars have a reset sequence for these, not familiar with them in an 86 though.
Anyway, that is the first thing I would look at or consider.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#3 | |
Drives: 2013 BRZ Limited 6MT
Drives: Subaru BRZ
I wouldn't expect anything less in a "proper" sports car...
Database error
Straight Pipes' would say "It's a supercar pass"
![]() The real question is, does your car pass the visor test? [ame="https://www.youtube.com/watch?v=DuTM4KacaQg"]https://www.youtube.com/watch?v=DuTM4KacaQg[/ame] OP terribly sorry for trolling your thread. I couldn't stop myself ![]() Twins: 11:02 Last edited by korhun; 01-07-2020 at 01:48 PM. |
I found this way more entertaining than I should have....
| Tags |
| heat, heater, hvac, no heat |
| Planted Seat Brackets - FRS / BRZ / 86 - Driver and Passenger Side | Redline360 | Interior Parts (Incl. Lighting) | 0 | 08-01-2019 08:33 PM |
| Heat is hot on driver side and cold on passenger. | Peanrocks | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 11-30-2018 12:55 PM |
| Warm air drivers side, cold air passenger... | elitegunslinger | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 06-12-2018 10:23 AM |
| heat on one side ice cold on the other? | DarkCard | Issues | Warranty | Recalls / TSB | 4 | 02-15-2015 03:22 PM |
| wtb brz driver and passenger side sun visors | nerdgsr | Want-To-Buy Requests | 3 | 04-29-2014 04:28 PM |
