Old 06-25-2017, 06:10 PM   #1
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
Warm air drivers side, cold air passenger...
I have a 2014 limited BRZ with the dual climate; I think the air mix door actuator on the drivers side has stopped working. I get warm air on the drivers side but cool air on the passenger.
I'll have to contact the parts department at Subaru or Toyota; does anyone have any ideas if I am going in the right direction?
elitegunslinger is offline   Reply With Quote
Old 06-25-2017, 07:13 PM   #2
elitegunslinger
That's not it, just looked at the servo and watched it on my back move and change to hot and cold with no problem.
I guess I can still check the pressure and level of refrigerant to make sure everything is good; seems strange because the passenger side is fine.
Old 06-26-2017, 06:31 PM   #3
elitegunslinger
The manual is correct; 30 psi @ 75 degrees, needed to be 40 psi. Now it's cold as ice and I don't have to sacrifice your AC.
Old 07-26-2017, 05:17 PM   #4
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
Having the same issue on my 2013, driver side is warm, passenger side is cool. But both take a minute or two to get cold now. Once I start getting some speed or on the freeway they cool, but if I'm sitting in traffic or stopped for a minute they get hot again.
Did you replace some parts or adjust some settings? Wondering how to go about it on my car, thanks!
pinetree is offline   Reply With Quote
Old 06-12-2018, 10:23 AM   #5
elitegunslinger
Sorry for the late response; I needed to charge my AC system back up. It was the low pressure side. Ended up using the AC Pro because it had a conditioner for the rubber gaskets to prevent future leaks.
Cant find passenger window wire from drivers side remote.. help? luv85 Electronics | Audio | NAV | Infotainment 2 11-03-2020 09:13 AM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 04:53 PM
Sounds nice when cold, boring when warm atledreier Engine, Exhaust, Transmission 11 08-07-2013 04:41 PM
Cold Wheels on Warm Hubs. Captain Snooze Tracking / Autocross / HPDE / Drifting 4 06-10-2013 12:29 PM
