Drives: Subaru BRZ
Clutch/misfire issues need help.
Hey guys been having trouble with my car and could really use some help on this one...
I started experiencing problems about 5,000 miles after I bought and installed an ACT clutch and lightweight flywheel. It would have problems getting into gear from a stop. Continuing to drive the car it kept getting harder and harder to get into gear from a stop and now at this point the only was I have found to get it to go into gear is holding the clutch down for about 5-6 seconds then it will slid into gear fine. I only have this issue when the car is hot, while it is cold it seems to be functioning fine. I have bleed the clutch multiple time and replaced the slave cylinder which all seemed to help for a couple days then would go back to the same issue. I took the transmission back off and decided to take a look at the clutch, pressure plate, and flywheel and all seem to look fine. And now for the interesting bit... I decided to install the stock flywheel/clutch back into the car (originally when I removes it my throw out bearing was really bad and it had trouble getting into gear if this might of messed with the clutch/pressure plate/flywheel I’m not sure) and now the engine misfires pretty bad and stalls unless I rev it at idle. It’s also throwing codes P0011 and P0021 which has to do with a timing issue? Very confused by this and could use some help, thanks in advance! |
Drives: Subaru BRZ
Hmm didn’t even think of that. Thank you I’ll take a apart and look at it.
#3 | |
Drives: 2013 FRS
But yeah, definitely a good first thing to check here |
You either bent reluctor ring or got it on there wrong.. It would definitely explain the timing issues and misfiring!
Drives: Subaru BRZ
The reluctor ring was put back on wrong. Thanks everyone for the help!
not playing cards
I love a happy ending.
| clutch/tranny issues | beat1 | Issues | Warranty | Recalls / TSB | 8 | 06-26-2018 05:05 PM |
| Possible Clutch Issues | Strife26 | Engine, Exhaust, Transmission | 1 | 05-31-2018 03:10 AM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
| Clutch Adjustment Issues!! | FT-86- | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 05-28-2015 09:29 PM |
| Clutch issues | Mongo | Issues | Warranty | Recalls / TSB | 16 | 04-20-2013 12:10 PM |
