Old 12-30-2019, 03:37 PM   #1
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Block Plate replacement worth it?
I’m just sort of thinking out loud here. For everyone with a manual, have you replaced/re-sealed the block plate? I think mine is allowing a very small amount of oil to leak out. It doesn’t seem to be a big issue, but does it only get worse over time? Was this a bigger issue on the earlier FR-S? Mine is a 2016
I’ve watched the FT-86 Speed Factory replacement video, and it doesn’t seem too difficult, with a lift. I would be worried about missing some of the old sealant that could get in the oil, or new sealant getting in the oil.
JesseG is offline   Reply With Quote
Old 12-30-2019, 03:43 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Issue among the earlier models. Some people replaced it with aftermarket but still leaked. Mainly due to the sealant being applied incorrectly I believe.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
JesseG (12-30-2019)
Old 12-30-2019, 04:16 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Once the sealant hardens, there should be no way for the sealant to mix with the oil after hardening.
I'd say if it's leaking, it's worth doing- if it starts dripping on the exhaust, you're risking a fire. Even if it is a low chance, it's worth getting it taken care of.
The Following User Says Thank You to DarkPira7e For This Useful Post:
JesseG (12-30-2019)
Old 12-30-2019, 04:19 PM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Sealant shouldn't be an issue, even if you apply a lot. This isn't like the valve spring recall where it's super easy to "misplace" the coolant.
There might be some used ones for sale on here, if not there will be one soon Or just take yours off an reseal it to try to fix it that way first.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
JesseG (12-30-2019)
Old 12-30-2019, 04:22 PM   #5
JesseG
JesseG's Avatar
Yeah it sounds like the replacement plate wasn’t installed correctly then.
Old 12-30-2019, 04:24 PM   #6
JesseG
JesseG's Avatar
Ok now I’m moving this up on my car To Do list
Old 12-30-2019, 04:27 PM   #7
JesseG
JesseG's Avatar
So just be careful getting the old sealant removed, and apply enough for a good seal with the new plate? Is there a specific tool that is best to scrape the old stuff off? I have some putty knives that might work.
And if you put yours up for sale let me know.
Old 12-30-2019, 04:35 PM   #8
chickunfut
Low-Buck Ramp Truck
chickunfut's Avatar
Drives: 2016 Scion FR-S Release 2.0 #502
I used a blunt nylon trim panel tool to get ALL the old sealant off. Got everything off without any nicks.
I'm using the Verus plate which uses an o-ring to seal. It's a little more critical that you remove all sealant in the groove since that's where the o-ring sits. You probably wouldn't need to be so thorough if you're going back with stock plate and sealant..
chickunfut is offline   Reply With Quote
The Following User Says Thank You to chickunfut For This Useful Post:
JesseG (12-30-2019)
Old 12-30-2019, 04:44 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'll have a red Verus for sale shortly, probably Wednesday. Just need to pull it off the car it's on.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
JesseG (12-30-2019)
Old 12-30-2019, 04:49 PM   #10
JesseG
JesseG's Avatar
Ok gotcha, those are helpful tips!
Old 12-30-2019, 04:50 PM   #11
JesseG
JesseG's Avatar
Ok cool!
Old 12-30-2019, 04:50 PM   #12
JesseG
JesseG's Avatar
And you guys haven’t had any oil leaking with the Verus plate?
Old 12-30-2019, 04:53 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No evidence of it on this car. It's a salvage car that we bought for it's parts and to move the engine to a 2015 hydrolocked car we have. We planned to swap to a stock plate instead of the aftermarket one to get some money back on the car. It's sadly almost cheaper to just buy a salvage car to get the engine vs buying a used engine elsewhere.
I suggested trying to reseal it cause it should, in theory, work. IMO the aftermarket plates are more for show. :shrug: But then I've never had an issue with an OEM one leaking when sealed correctly.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
jcw99 (12-31-2019), JesseG (12-31-2019)
Old 12-30-2019, 04:57 PM   #14
chickunfut
Low-Buck Ramp Truck
chickunfut's Avatar
No issues so far, but my car is not a daily driver. Probably around 200 miles with no issues. Plate was installed 3-4 months ago..
JesseG (12-31-2019)
Glittery engine oil after short block replacement msaikhan Issues | Warranty | Recalls / TSB 17 08-24-2019 02:17 PM
Block replacement under warranty - what all needs to be replaced? chipmunk Engine, Exhaust, Transmission 8 02-16-2019 09:29 PM
If my car had an engine replacement: short block, am I still able to get a super char VeganGirl Forced Induction 2 07-20-2016 08:35 AM
Full long block replacement, who has done it themselves? post_break Engine, Exhaust, Transmission 14 06-20-2014 05:56 PM
Reverse light block off or replacement? STS-V Cosmetic Modification (Interior/Exterior/Lighting) 31 04-10-2014 07:06 PM
