Old 06-18-2014, 03:48 PM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Full long block replacement, who has done it themselves?
I'm curious as to who has changed/replaced their entire engine themselves. What is required ECU wise to get the new motor in? Is it as simple as removing the old motor, swapping the ECU onto the new motor, fluids and wires, and firing it up?
post_break is offline   Reply With Quote
Old 06-18-2014, 04:58 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You don't swap the ECU per say as that is mounted in the car. You will disconnect the wiring harness from everything and move it out of the way and then remove the motor and then reinstall the motor and hook all the connectors back up. Hopefully you can just move the A/C compressor out of the way enough to not have to crack open the lines. I would remove the front bumper, cooling fans, radiator, and radiator support to give you room to get the motor out the top. I would leave the tranny in place. Be very careful with the coil packs and anything else that can get damaged by hitting the frame rails when you pull and reinstall the motor. I haven't done an FA20, but I have been part of multiple EJ motor pulls.
The Following User Says Thank You to King Tut For This Useful Post:
post_break (06-18-2014)
Old 06-18-2014, 05:05 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
I am not sure about this car, but with other boxer LB swaps there are a couple of important steps other than just swapping it.
There could be crank endplay checks and shims required to install.
And if the flywheel bolts are of a certain type, then you need to replace them.
Sounds like you need the real factory manual.
Not sure if the one we have available goes into all of those details.
Old 06-18-2014, 05:13 PM   #4
Dipstik-sportech
Dipstik-sportech's Avatar
I did it in my buddies driveway without air tools in 7hrs
The Frozen North
Old 06-18-2014, 05:23 PM   #5
andrew20195
Drives: 2013 Subaru BRZ
It might be possible, but there isn't much hose to work with to pull the compressor out of the way. Having the luxury of working in a dealer I always just recover/recharge.
No need for this, there is plenty of room to move the engine forward if you remove the exhaust manifold, which shouldn't be too hard even on jack stands.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
Old 06-18-2014, 07:44 PM   #6
FirestormFRS
I'm pretty sure that flywheel bolts are plastic region bolts and will need replaced. I've never ran into any flywheel bolts that weren't.
FirestormFRS is offline   Reply With Quote
Old 06-18-2014, 08:10 PM   #7
stugray
I read the manual. It actually does go into enough detail to do this yourself.
There is no endplay meas. mentioned, just bolt & go.
Old 06-19-2014, 12:02 AM   #8
xwd
I have done this on a bunch of Subarus and it is generally just bolt and go. Sometimes to do a clutch I would pull the engine if there was no lift, took about 45 minutes. Took about an hour or so o put back in since the coolant had to be put back in.
Old 06-19-2014, 09:24 AM   #9
andrew20195
Neither flywheel nor pressure plate bolts are tagged as one time use in the service manual.
Old 06-19-2014, 09:35 AM   #10
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I can confirm they are metal bolts. I did replace them with ARP flywheel bolts.
Removing a motor does require to pull the gearbox or can that be left in place?
F1point4 is offline   Reply With Quote
Old 06-19-2014, 09:57 AM   #11
The Slow One
Track Junkie
Drives: Argento Scion FR-S
The transmission can be left in place, but you just need something to support the front portion of the transmission.
The Slow One is offline   Reply With Quote
Old 06-19-2014, 11:06 AM   #12
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
In most cars, I would pull the engine with the trans. But in this car the trans is so easy to remove, it probably makes little difference either way. Once you get the airbox out of the way, there is a ton of room, too, so the radiator and fans can probably be left in place.
Probably the most annoying part of the swap in these cars would be pulling and reinstalling all coolant/fuel hoses and electrical harness.
FrX is offline   Reply With Quote
Old 06-19-2014, 11:17 AM   #13
FirestormFRS
If the pressure plate/clutch cover bolts have lock washers they are one time use. Just a rule of thumb used by most. I find it hard to believe the flywheel bolts aren't plastic region but Subaru is unique in many ways.
Old 06-19-2014, 02:27 PM   #14
andrew20195
Yeah, I was a bit surprised to find that not only are head bolts not single use, but there are also no maximum stretch measurements. I worked on Honda/Acura for 10 years before moving to Subaru, and the early head bolts are one time only while the later design have a thickness spec.
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 07:29 PM
FS: FA20 Long Block w/ Rod Knock Dan@AWD Engine, Exhaust, Bolt-Ons 16 06-12-2014 09:05 AM
FA20 Long Block and Port/Polish "Bare" Heads Allaskew Engine, Exhaust, Bolt-Ons 1 06-08-2014 12:48 AM
Reverse light block off or replacement? STS-V Cosmetic Modification (Interior/Exterior/Lighting) 31 04-10-2014 07:06 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
