Old 12-27-2019, 06:52 PM   #1
Dububster
Dububster's Avatar
Strange Rattle above 2500 rpms??
Hey Everyone. So I've been noticing this strange rattle noise for the past few months and it seems to be getting worse. It only happens above 2.5k rpms, never if my foot is off the throttle in neutral, and only after I have been driving for a bit (never when I first start up the car and get going). Everything on my car is stock (unfortunately) and I have no idea what the noise is. I'll attach a link to the noise for you guys to take a look at.
Dububster is offline   Reply With Quote
Old 12-27-2019, 06:56 PM   #2
kev0
Drives: '14
Always go under the car and check the metal plate under the header first. The heat shield on the front pipe/header might be getting loose as well.
kev0 is offline   Reply With Quote
Old 12-28-2019, 06:03 PM   #3
Dububster
Dububster's Avatar
I took a look under and noticed a few things on the header were a bit loose but they don't seem loose enough to cause the noise. Do you think so?
Old 12-28-2019, 08:09 PM   #4
Dububster
Dububster's Avatar
Here’s another video of the noise if it helps.
Old 12-28-2019, 09:00 PM   #5
Stomachbuzz
Drives: 2013 FRS
Exhaust.
Stomachbuzz is offline   Reply With Quote
Burbling / gurgling noise at 2500-3000rpm, knock, rattle? (Video inside) highway7 Issues | Warranty | Recalls / TSB 17 01-06-2018 02:32 AM
Deep rattle/vibration in 1900-2500 RPM Band Sh1FTy Engine, Exhaust, Transmission 9 07-10-2016 11:20 PM
Poor response/power below ~2500 rpms? New car. Formula Vee Issues | Warranty | Recalls / TSB 21 02-16-2014 02:33 PM
Strange noise at 2500 RPM midnight23 Engine, Exhaust, Transmission 7 06-07-2013 09:01 AM
Strange noise at 2k RPMs Cajun Issues | Warranty | Recalls / TSB 3 11-29-2012 10:30 PM
