Old 06-26-2016, 06:32 PM   #1
Sh1FTy
Drives: Toyota 86 Pegasus White
Deep rattle/vibration in 1900-2500 RPM Band
Hi guys,
The exhaust setup at the moment is PSR UEL Headers and Overpipe with a Berk HFC Front Pipe. Previously with just the PSR UEL Headers and Overpipe I had no issues. After I had installed the front pipe I've been getting some sort of deep rattle/vibration from behind me, kinda like a reverberating trombone noise between 1900-2500 RPM. It becomes very apparent from 1900 RPM and slowly dies down from 2500 RPM onwards.
I will be checking under the car over the next few days to check if everything's been installed and tightened correctly but are there any theories on what it could be?
Sh1FTy is offline   Reply With Quote
Old 06-26-2016, 07:03 PM   #2
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
I'd bet money on overpipe hitting/rubbing crossmember.
I know it sounds like it's coming from behind you... That's interesting. Doesn't fit the problem...
All speculation is meaningless until someone gets under there and checks for contact.
I almost guarantee this issue is a clearance issue.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 06-26-2016, 07:31 PM   #3
Teseo
Drives: frs
Looks identical of tomei/gruppe s
Old 06-26-2016, 08:05 PM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You removed the heimholtz in the stock fp that's tuned for this exact rev range.
Is it vibration or is it valve overlap noise? They're two entirely different problems.
Old 06-26-2016, 09:18 PM   #5
Sh1FTy
It's definitely a vibration/deep rattle sound.
Old 06-26-2016, 10:37 PM   #6
dtrop
Drives: Wrb 2014 limited brZ
While this may not be the issue for you, it was with me.
I installed a JDL uel header and a quarter sized section was in contact with the skid plate. I took the skid plate off and banged it with a hammer and now I have no issues.
dtrop is offline   Reply With Quote
Old 06-26-2016, 10:58 PM   #7
Sh1FTy
Was your issue with a specific RPM band as well or across the board?
Old 06-26-2016, 11:02 PM   #8
dtrop
Somewhat, yes.
sound captured at 0:03-0:08 seconds
Old 06-26-2016, 11:58 PM   #9
humfrz
Yep, I agree.
Another job for a crowbar and bailing wire ........
humfrz
Old 07-10-2016, 11:20 PM   #10
Sh1FTy
I swapped out my stock catback for a Blitz Nur Spec C-Ti catback on the weekend and the rattle is now gone. Perhaps it was just a resonance issue with the stock catback?
rattle and vibration when braking? dokterdewe Issues | Warranty | Recalls / TSB 19 09-01-2019 08:44 AM
How deep is too deep? (hydro lock) Muskokan Scion FR-S / Toyota 86 GT86 General Forum 12 01-11-2014 10:59 PM
Exhaust vibration/rattle at cold start? Foobar Engine, Exhaust, Transmission 7 04-16-2013 05:15 PM
crazy person askin 1900 for stock rims whitefrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-07-2012 07:59 PM
