Old 12-17-2019, 02:10 PM   #1
solidsnake11
Drives: brz
21lbs of boost @ 8000rpms blown head gasket.
Censored
solidsnake11 is offline   Reply With Quote
Old 12-17-2019, 02:55 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You should probably get a build thread and update it with all these things you go through instead of making threads in the technical topic sub-forum.
Sorry to hear it though, that sucks. it probably won't run fine for long. Coolant will contaminate your oil sooner than later if you drive it like that.
The Following User Says Thank You to DarkPira7e For This Useful Post:
ATL BRZ (12-18-2019)
Old 12-17-2019, 03:10 PM   #3
DarkPira7e
DarkPira7e's Avatar
Originally Posted by solidsnake11 View Post
Sorry!!
No need to be sorry, it'd just be easier to keep track of what you're endured and fixed if you had a build thread
Old 12-17-2019, 03:17 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
This is better because it gives notification of a specific issue and any follow up comments, instead of having to find and look through a random build thread and never knowing if/when something relevant to that specific issue pops up. your posts are in the correct location.
What are your plans for making sure you don't blow a head gasket again?
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
fika84 (12-18-2019), solidsnake11 (12-17-2019)
Old 12-17-2019, 04:04 PM   #5
86TOYO2k17
If I was going to stick with the fa20 I would make sure the surfaces were flat and ARP head studs.
Are you planning a swap now?
Old 12-17-2019, 04:15 PM   #6
tomm.brz
Drives: brz 2017 hksv2
I really have much respect for you and for your crazy build, even if I Don t know you and started reading from you only lately
And I don't really understand a lot of your choices of going cheap in things like that!!
But I really hope you ll stick with fa20 and make it even more extreme as now, looking forward to it
Cheers
The Following User Says Thank You to tomm.brz For This Useful Post:
gtengr (12-18-2019)
Old 12-18-2019, 04:23 PM   #7
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Interesting, do you have a build thread with supporting mods? I'm at 10 PSI, tuner says I can raise it slightly starting at 1 more but everyone says not to. Everything is stock and on 93 pump gas, no E85 in my area.
Heard the transmission will go before the rods will, something about 4th gear will be the first as the sudden shock to the drive train.
Clueless
YamahaR86 is offline   Reply With Quote
Old 12-20-2019, 09:46 PM   #8
jflogerzi
jflogerzi's Avatar
On pump, stock trans should hold up for a while at your power levels. The extra 1 psi is not gonna get you much. Leave be and enjoy.
2013 Series 10 FRS #553
Old 12-21-2019, 12:46 AM   #9
HaXx
Drives: jrsc_brz
Lmaoooooooooo solidsnake you are my hero. Here's my mental image of you: garage door is open till 2am every night, then the garage light goes out. Your kid could win the flashlight holding Olympic gold. Empty beer cans everywhere. Your wife asks in the am "u fix it yet?" You answer "not yet but I'm getting closer". Cheers to you and all the physical, hands on, greasy handed, aching back, blood sweat and tears you put in.
HaXx is offline   Reply With Quote
The Following 2 Users Say Thank You to HaXx For This Useful Post:
gkubed (12-26-2019), solidsnake11 (12-21-2019)
Old 03-10-2020, 09:38 AM   #10
dholloway543
Software Hobbiest
Drives: 2015 FRS
What is the CP ratio on your pistons to be running 21 LBs of boost?
Im at 11.5 CP and my max capable boost is 8-10psi before the limit of 91 octane
dholloway543 is offline   Reply With Quote
I think I have a blown head gasket; what would you do? Timmy_Jones Issues | Warranty | Recalls / TSB 28 11-28-2018 10:34 AM
Toyota 86/ FRS / BRZ Blown Head Gasket Twin-Dragons Scion FR-S / Toyota 86 GT86 General Forum 4 09-02-2018 03:47 PM
Blown head gasket?? sachu Issues | Warranty | Recalls / TSB 14 07-15-2016 01:08 PM
Blown head gasket?? texasbound972 Engine, Exhaust, Transmission 29 05-19-2015 11:09 AM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 09:45 PM
