86WORX
Old 11-25-2018, 03:44 PM   #1
Timmy_Jones
Spun
Drives: 17' Focus RS
I think I have a blown head gasket; what would you do?
1
Timmy_Jones is offline   Reply With Quote
Old 11-25-2018, 06:03 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
It's likely cheaper to fix it rather than buy a new vehicle. Do you like the car?
Also, I'd probably make sure a head gasket is your issue to begin with.....
Old 11-25-2018, 06:46 PM   #3
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Are you in the recall ?? Could offset some of the cost if you are
22R
22R is offline   Reply With Quote
Old 11-25-2018, 06:56 PM   #4
Find out if that is really the issue.
Summerwolf (11-25-2018)
Old 11-25-2018, 07:39 PM   #5
Ultramaroon
fabulous
Ultramaroon's Avatar
Then whatever it is, get it fixed.
Ultramaroon is online now   Reply With Quote
Tcoat (11-25-2018), Timmy_Jones (11-25-2018)
Old 11-25-2018, 07:54 PM   #6
Timmy_Jones
Spun
22R
How can I find out?? Car is a 2013.
Old 11-25-2018, 07:55 PM   #7
Timmy_Jones
Spun
Either gasket or the head is cracked...
Would you have concern about coolant mixing in the oil harming other parts of the engine?
Old 11-25-2018, 08:02 PM   #8
humfrz
Go to "safercar.gov" and put in your car's VIN.
Or go to the Toyota website and look under recalls.
If your car is on the recall list, and they have to takes the heads off to replace the valve springs, that would fix any leaking head gasket problem.
Are you sure you didn't spill something sweet in the trunk?
humfrz
Old 11-25-2018, 08:06 PM   #9
humfrz
Usually if coolant gets into the oil, a milky residue will be seen on the dip stick.
Well, coolant in the oil sure as hell isn't gonna do the engine any good -
humfrz
Old 11-25-2018, 08:31 PM   #10
alphasaur
friendly
Drives: 17' 86
humfrz
doesn't our oil run hot through
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-25-2018, 08:31 PM   #11
Summerwolf
Panda Trueno
Summerwolf's Avatar
I have had a subaru with a blown head gasket. Milkshake oil and lost coolant were the only symptoms. I had the engine basically took down to the short block and rebuilt.
It spun a bearing within 10k. I still would have been better off financially by replacing the motor as opposed to buying a different car. I bought something different because I wanted it.
If you like this car, figure out what's wrong and go from there. Fix it or replace the motor. If you don't like it....this is as good an excuse as any to trade out.
The Following User Says Thank You to Summerwolf For This Useful Post:
Old 11-25-2018, 09:47 PM   #12
Timmy_Jones
Spun
humfrz
Wow - it is under this recall. I will call Toyota tomorrow!
Old 11-25-2018, 09:55 PM   #13
alphasaur
friendly
Drives: 17' 86
Interested as to how the head gasket blew
Old 11-26-2018, 12:10 AM   #14
humfrz
OK, hot chocolate residue -
humfrz
alphasaur (11-26-2018)
Head Gasket Oil Leak - this is what one might look like exE36M3 Issues | Warranty | Recalls / TSB 36 02-14-2021 02:27 AM
Toyota 86/ FRS / BRZ Blown Head Gasket Twin-Dragons Scion FR-S / Toyota 86 GT86 General Forum 4 09-02-2018 04:47 PM
Blown head gasket?? sachu Issues | Warranty | Recalls / TSB 14 07-15-2016 02:08 PM
Blown head gasket?? texasbound972 Engine, Exhaust, Transmission 29 05-19-2015 12:09 PM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 10:45 PM
