Old 12-16-2019, 12:53 PM   #1
Petah78
Drives: 2022 BRZ sport-tech
Amsoil Syncromesh MTF - anyone using it?
Anyone using Amsoil Syncromesh MTF in their manual transmissions? I know the viscosity is not properly weighted as factory calls for a 75W-90 fluid but my "new to me" BRZ is having a hard time with initial shifting when it gets cold out. I have read many threads and it appears that this is "normal" behavior of this car and some have somewhat remedied this by using a new fluid. I believe our car's transmission is an inhouse unit (TL70) which is a variation of the Aisin AZ6 (similar to the S2000, RX8 and Miata). I have used the Amsoil Syncromesh MTF in my S2000 with no issues. There are also suggestions of using Pentosin MTF2 (also a thinner oil and not per factory specs) in colder climates with great success but that is now discontinued.
But i have also read that some fluids are not brass synchros/yellow metal safe? Can anyone chime in?
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Manual trans, IRP sort shifter, Whiteline diff bushing, Syncromesh carbon syncs laextreme5 Transmission and Driveline 18 01-11-2020 10:33 AM
Amsoil 0w-20 Krewcial5050 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-30-2018 03:29 PM
Gear Oil :) Amsoil Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-12-2015 12:41 AM
Question for oil junkies regarding Amsoil OE vs Amsoil Signature Simon99 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-25-2014 10:48 AM
Amsoil sanmarcosfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-11-2013 09:10 AM
