Old 12-15-2019, 09:17 PM   #1
solidsnake11
Drives: brz
CD009 clutch info
C
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
Irace86.2.0 (12-15-2019)
Old 12-15-2019, 09:27 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by solidsnake11 View Post
I have a swapped CD009 with a lightweight flywheel and solid hub clutch. I just wanted to let people know that the rattling from the solid clutch trips the knock sensors and drops the IAM. Take this into account if you plan to do the swap.
I disabled my knock below .90 load and 3200rpm. Motor is FA20 10.5 to 1.
Are you switching to a sprung clutch disk, or is this a track only car, which is why you decided to disable the knock sensor because you want to keep the clutch, or maybe that is a temporary solution until you replace the clutch? Do you think this is unique to the FA20 or a common problem with solid clutches?
I don't have experience with such a clutch, but I understand that they aren't fun on the street.
FBM drag car to 2JZ/CD009/FuelTech skreet car build Stevemode Engine Swaps 19 12-27-2019 11:39 PM
CD009 350Z Transmission into FT86 Swap xoBethxo Engine, Exhaust, Transmission 26 07-02-2019 10:39 AM
2JZ VVTi With CD009 Mounts Are Complete! Pure Automotive Engine Swaps 4 02-15-2018 01:30 PM
NOW AVAILABLE!! PURE 2JZ VVTI W/ CD009 TRANSMISSION MOUNT KIT FOR FRS/BRZ/GT86! Pure Automotive Engine Swap 0 02-15-2018 09:51 AM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
