| Engine Swaps Discussion of engine swaps. |
Drives: 2013 FRS Whiteout
2JZ VVTi With CD009 Mounts Are Complete!
Very happy to announce that our mount kits are in stock and ready to go ! Please use this thread to ask any questions about VVTi and CD009 fitment into the chassis!
Introducing our new mount kit to mate your FT86 chassis (FRS/BRZ/GT86) with the mighty Toyota 2JZGTE VVTi engine and the Nissan CD009 6 speed manual transmission! This kit will include the left and right engine mounts which are a bracket and a 95a urethane mount along with the mounting bracket and polyurethane transmission mount for the CD009 transmission. All hardware included is grade 10 JIC for maximum strength. The kit does not include the 2JZ to CD009 Transmission Adapter kit, that kit is sold separately, email us for more info! You WILL have to heavily modify the transmission tunnel to accommodate the CD009 transmission as it is much larger than the stock transmission. Factory mounting brackets must be removed and the tunnel must be opened up quite a bit. The engine fits with only a few small modifcations including removing the factory strut bracing bracket and notching the front lower core support. IMG_4266 by Brady Johnson, on Flickr IMG_4267 by Brady Johnson, on Flickr IMG_4268 by Brady Johnson, on Flickr
Drives: 2013 Ultramarine FR-S
Looks like exhaust is going to be super tight under that trans mount.
#3 | |
Drives: 2017 WR BLUE BRZ
@pureautomotive, Looks great! What do you guys suggest for routing an exhaust under the mount? |
Drives: 2JZ FRS
if photobucket didn't ruin everything I would post the pic of my old car with the 3" oval routing. We run them next to the tunnel along the floor. Never had a ground clearance issue. Most transmissions are so big the tunnel is dead for anything exhaust related.
| 1UZFE vvti into GT86 - vids, pics, comments | Manji | Engine Swaps | 62 | 11-12-2021 12:52 PM |
| CD009 350Z Transmission into FT86 Swap | xoBethxo | Engine, Exhaust, Transmission | 26 | 07-02-2019 10:39 AM |
| How does VVTi work? | MrDinkleman | Engine, Exhaust, Transmission | 4 | 11-21-2017 06:25 AM |
| Window weld motor mounts (poor man's solid mounts) | unsurety | Engine, Exhaust, Transmission | 8 | 06-05-2014 02:36 AM |
| Driving car with bad VVTI gear need help | CharlieChaos | Issues | Warranty | Recalls / TSB | 19 | 09-08-2012 10:22 AM |
