Old 12-15-2019, 02:39 PM   #1
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
Help removing the dipstick tube! urgent?
Hey guys been getting a lot of help from this form, this time i tried installing a nameless long tube headers (heat wrapped). Because it’s a long tube header design the fitment is pretty tight. many people either relocated the Engine dipstick to wiggle around the headers or just removed the dipstick tube completely. because mine is wrapped looks like i have to just remove the dipstick tube and put it back on once i install the headers. anyone know how to remove dipstick tube from the engine block?
SamtheKorean is offline   Reply With Quote
Old 12-15-2019, 04:21 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
You have to remove the dipstick tube. It's pretty easy. Just unbolt the 10mm nut and then pluck it out. Also for the Nameless headers you need to move one of the fan wires down so it doesnt melt.
MS, CSCS, TSAC-F, CPT
Old 12-15-2019, 04:35 PM   #3
SamtheKorean
September
Drives: 2015 BRZ
do you think heat wrap would change any results? if I cant get it in after removing the dipstick I'm planning to just remove all the heat wraps I put on.
Old 12-15-2019, 04:50 PM   #4
weederr33
weederr33's Avatar
Theres plenty of room once the dipstick is removed
Old 12-15-2019, 06:22 PM   #5
SamtheKorean
September
Drives: 2015 BRZ
most simple thing takes the longest... seems that tube doesn’t really like to come off. is there certain way that the tube has to come out? i’m able to rotate it and wiggle it but it’s stuck stuck. any tips on this?
Old 12-15-2019, 08:41 PM   #6
weederr33
weederr33's Avatar
Once the stick is removed, and 10mm bolt at the top is taken off, you just need to give it a damn good pull and it will pop off. It's just an O-ring holding it in. Maybe pulling from under the car so you can get a better tug on it might help.
Old 12-15-2019, 10:34 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Attached is a picture of the tube already out of the car so you can see what you're up against.
As previously stated, you just have to pull on it. Maybe you're just being a little too careful and have to try a bit harder.
Joon525 is offline   Reply With Quote
Old 12-15-2019, 11:32 PM   #8
SamtheKorean
September
Drives: 2015 BRZ
Thanks for the pic i live in a place where its very humid. looks like i got a good rust build up, i'm gonna give it more good yank again tomorrow.
Old 12-16-2019, 12:29 PM   #9
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Might pick up a new O-ring.
I've heard some of the valve spring repairs are being bodged up with RTV.
Old 12-16-2019, 11:41 PM   #10
SamtheKorean
September
Drives: 2015 BRZ
Update on dipstick tube. Thanks everyone literally walking me through every step amazing community. Installed my long tube header and wow it’s so much louder.
Also very raspy like 350z exhaust raspy and trumpet like? however def power increase on my butt dyno lol. Specially topend is just keep bringing more power, not so much in mid range. But i gotta find a way to quite down a bit, lmk if y’all got any tips😎
Old 12-16-2019, 11:57 PM   #11
weederr33
weederr33's Avatar
Good to hear you got it out!
Yes, the Nameless headers are very raspy, but damn is the power worth it. There isn't much to help with the rasp, except maybe coating them or wrapping them. Or overpowering it with a sweet exhaust note. lol
Old 08-05-2023, 02:13 AM   #12
r4mr4m3024
Drives: gt86
I want to buy o-rings for this part, what kind of o-rings can I buy? Because when I push the car, I have an oil leak on my header, I feel that this is the problem
r4mr4m3024 is offline   Reply With Quote
Old 08-05-2023, 10:45 AM   #13
bcj
Geo Tyrebighter Esq
bcj's Avatar
The hardware or box store.
They've also got RTV sealant.
Clean the area thoroughly with degreaser then probably use both just because.
Old 08-05-2023, 05:58 PM   #14
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It will be worth your time to clean the area thoroughly and examine. I very much doubt the dipstick tube is leaking of its own volition- valve cover gaskets on the other hand, or the timing over itself... that's where I would direct my suspicions first.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Dipstick leak ? Geex Issues | Warranty | Recalls / TSB 7 12-17-2019 03:43 AM
Dipstick removal Geex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 03-06-2019 01:55 PM
Oil leak near the base of the dipstick tube gravitylover Engine, Exhaust, Transmission 35 07-17-2017 12:45 PM
Removing sound tube ArtS Engine, Exhaust, Transmission 3 01-24-2015 05:04 PM
Removing the sound generator tube Jcadillo Scion FR-S / Toyota 86 GT86 General Forum 2 07-11-2013 10:59 PM
