Old 07-07-2017, 07:42 PM   #1
gravitylover
Oil leak near the base of the dipstick tube
Sitting still this afternoon I saw smoke coming out form under the hood so pop it and take a look. It appears to be coming from somewhere near the base of the dipstick tube and running underneath and dripping onto the exhaust. There was a fair bit of crusty buildup in the area so I sprayed it with some engine cleaner and sprayed it down while it was hot, it came out pretty clean so now I can get a look at it without the buildup.
Does someone have a picture of that part of the engine with it out of the car so I can get an idea of what I'm looking at while it's clean and compare it to what I saw and keep an eye on it going forward? Thanks.
Old 07-07-2017, 08:13 PM   #2
stevesnj
stevesnj's Avatar
There's an O-Ring on the bottom of the tube. It could be damaged. Just unbolt the tube and pull the tube out to inspect.
My 2016 Build thread
The Following 3 Users Say Thank You to stevesnj For This Useful Post:
gravitylover (07-07-2017), humfrz (07-07-2017), Kwaziekeller (07-10-2017)
Old 07-07-2017, 09:32 PM   #3
humfrz
For want of a nail, the shoe was lost, for the want of a shoe, the horse was lost ..........
humfrz
Old 07-07-2017, 09:35 PM   #4
Why two threads on this there Grav?
Old 07-07-2017, 11:18 PM   #5
Since the other is closed and for anybody with the same issue here is the TSB that covers this and several other common leaks.
http://www.ft86club.com/forums/attac...1&d=1413834741
Old 07-07-2017, 11:49 PM   #6
Teseo
Drives: frs
The question still remain, why got closed?
Old 07-08-2017, 12:01 AM   #7
Duplicate post in wrong section. No drama.
Old 07-08-2017, 12:01 AM   #8
Duplicate thread in wrong section. No drama.
Old 07-08-2017, 01:16 AM   #9
gravitylover
Some people don't seem to check every sub forum and I figured max exposure...
Thanks. Unfortunately I don't think those are the problem but at least now I have something to keep an eye on. I guess there's a chance it could be #3 but usually when there's a leak it would drip/run down not go up. This is on the passenger side of the motor and starts higher than the oil pan.
The Following User Says Thank You to gravitylover For This Useful Post:
Tcoat (07-08-2017)
Old 07-09-2017, 07:36 PM   #10
gravitylover
Still seeing smoke after I thought I had all of the old grimy stuff cleaned off. I'd really love to see a pic of the bottom of the motor above the exhaust on the passenger side of the car so I can formulate some sort of idea where the oil is coming from.
Old 07-09-2017, 07:42 PM   #11
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Whatever happened to wiping things down with a rag.
Ffs. I never wanted the world to get involved the first time my points closed up on my old mini in the 70s
Does everyone need a hug. Group keyboard hug?
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Ultramaroon (07-09-2017)
Old 07-09-2017, 11:16 PM   #12
Turdinator
Señor Member
Turdinator's Avatar
This.
Unbolt it with a 10mm socket. Take the dipstick and oring to a bearing or seal place. Buy new oring for a couple of dollars. Slip it back in the hole. Do up the bolt. Get on with life.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Tcoat (07-10-2017)
Old 07-10-2017, 06:13 AM   #13
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
^ you can also get the o-ring from the dealership for something like .68 lol. Remember to apply some oil to it before you put it back in so it doesn't tear.
Kwaziekeller is offline   Reply With Quote
Old 07-10-2017, 08:46 AM   #14
stevesnj
stevesnj's Avatar
Originally Posted by Turdinator View Post
This.
Mr. Know it all! You and your "10mm socket" JK
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Silver Supra (07-10-2017), Turdinator (07-11-2017)
Dipstick leak vs Timing Chain Cover jpeaslee Issues | Warranty | Recalls / TSB 6 03-03-2017 12:33 AM
Oil level on dipstick... Da Brz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 11-21-2016 06:44 PM
Dipstick question Qwimby2 BRZ First-Gen (2012+) — General Topics 26 11-27-2015 12:59 PM
oil on dipstick but not on hole ZionsWrath Engine, Exhaust, Transmission 2 09-08-2014 07:46 PM
Show me your dipstick.... Trashed675 Engine, Exhaust, Transmission 6 01-03-2014 01:09 AM
