Dipstick removal
I want to remove the dipstick to replace the o ring, but i'm unsure if the oil has to be drained or not.
Thanks. |
The oil does not need to be drained. Pull the tube the oil will drain to the correct level all by itself.
not playing cards
Lift the front or drive it up ramps. That'll give you more than enough, even if overfilled a smidge.
Drives: 2013 Firestorm FR-S AT
I pull the dipstick out every time I change the oil with this to use the larger tube and it never leaks oil. https://www.amazon.com/America-5060T...omotive&sr=1-8
Just make sure your car is on level ground. |
#5 | |
Yes it would but the metal container is stronger than a plastic one. I can tell by the weight of the container when it has removed all the oil; and I always have an empty 5 qt jug available to dump the container in to before I add fresh oil to also make sure I have sucked all the old oil out.
| Dipstick leak ? | Geex | Issues | Warranty | Recalls / TSB | 7 | 12-17-2019 03:43 AM |
| Oil level on dipstick... | Da Brz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 11-21-2016 06:44 PM |
| Dipstick question | Qwimby2 | BRZ First-Gen (2012+) — General Topics | 26 | 11-27-2015 12:59 PM |
| oil on dipstick but not on hole | ZionsWrath | Engine, Exhaust, Transmission | 2 | 09-08-2014 07:46 PM |
| Show me your dipstick.... | Trashed675 | Engine, Exhaust, Transmission | 6 | 01-03-2014 01:09 AM |
