Drives: 2017 Subaru BRZ
Oil Leak
So im having an oil leak after 7 months of boosting. I took it to a mechanic and he said i have too much 90 degrees on my oil line which could cause the leak to come out. Anyone else have this issue? If so, any advice?
Sent from my SM-G960W using Tapatalk |
Drives: 13 FRS Firestorm
Pics? Is your car a manual?
Sent from my SM-G9600 using Tapatalk |
No pics, so just guessing here:
| The Following User Says Thank You to BertoFT For This Useful Post: | j_ros94 (12-12-2019) |
Rust bucket enthusiast
What the technician was inferring was that with too many 90 degree bends, you're adding pressure points on those fittings. The leak is probably from one of the fittings. Otherwise, an oil leak is a result of something having a hole, not being tight, or gasket material missing; it has nothing to do with your car being boosted.
Just find the source of the leak and have it fixed
| The Following User Says Thank You to DarkPira7e For This Useful Post: | j_ros94 (12-12-2019) |
Drives: 2013 FR-S Series 10
i would have them put a UV dye in the crankcase so at least they're not guessing
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#8 | |
#9 | |
the tech and bring it elsewhere for review if they're really suggesting that.The only place boost would force oil past are the PCV and crankcase. Those would leak internally though, not at a fitting. |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | j_ros94 (12-13-2019) |
#10 |
Drives: brz 2017 hksv2
a stock PCV can leak and boost can go inside crankcase actually.... guess what's inside the crankcase?
Usually it's adviced to use a WRX PCV or a oneway check valve between the PCV and the intake manifold |
#11 | |
#12 |
Update on my oil leak. It was coming from the oil pressure switch. Anyone wanna chime in to see if its an expensive cost or could easily be fixed at home kind of thing
#13 |
Drives: 2014 MY15 86 GTS
#14 |
Do not even try to fix it, a new oil pressure switch is about 10 dollars from Toyota
| Oil leak help please | TorontoNat | Engine, Exhaust, Transmission | 1 | 12-26-2018 01:36 PM |
| Oil Leak | Brz_racer | Engine, Exhaust, Transmission | 22 | 07-17-2017 04:28 PM |
| Oil Leak? | Tofu-86 | Forced Induction | 3 | 09-23-2016 03:47 AM |
| oil leak ! | frsqc | Issues | Warranty | Recalls / TSB | 5 | 07-01-2015 07:08 PM |
| Help - oil leak | tlim | Engine, Exhaust, Transmission | 4 | 04-10-2015 08:40 AM |
