Old 12-12-2019, 06:29 PM   #1
j_ros94
Drives: 2017 Subaru BRZ
Oil Leak
So im having an oil leak after 7 months of boosting. I took it to a mechanic and he said i have too much 90 degrees on my oil line which could cause the leak to come out. Anyone else have this issue? If so, any advice?
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 12-12-2019, 07:27 PM   #2
BertoFT
Drives: 13 FRS Firestorm
Pics? Is your car a manual?
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 12-12-2019, 07:34 PM   #3
j_ros94
Yeah manual. Didnt get a chance to take a pic
Old 12-12-2019, 08:13 PM   #4
BertoFT
No pics, so just guessing here:
The Following User Says Thank You to BertoFT For This Useful Post:
j_ros94 (12-12-2019)
Old 12-12-2019, 08:33 PM   #5
j_ros94
This could be it. Gotta check again in the morning
Old 12-12-2019, 09:03 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What the technician was inferring was that with too many 90 degree bends, you're adding pressure points on those fittings. The leak is probably from one of the fittings. Otherwise, an oil leak is a result of something having a hole, not being tight, or gasket material missing; it has nothing to do with your car being boosted.
Just find the source of the leak and have it fixed
Old 12-13-2019, 12:23 AM   #7
Decep
Drives: 2013 FR-S Series 10
i would have them put a UV dye in the crankcase so at least they're not guessing
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 12-13-2019, 08:55 AM   #8
j_ros94
Oh that makes sense Ill have it looked at and everything. Tech speculated since im boosted it starts leaking from one of those fittings when hitting boost.
Old 12-13-2019, 09:29 AM   #9
DarkPira7e
DarkPira7e's Avatar
Unless your forced induction is supplying forced air into your oil, this doesn't make sense. Oil pressure is driven by RPM (it's just a manual gear driven pump) so the WAY your car makes power doesn't affect oil pressure. I would the tech and bring it elsewhere for review if they're really suggesting that.
The only place boost would force oil past are the PCV and crankcase. Those would leak internally though, not at a fitting.
j_ros94 (12-13-2019)
Old 12-13-2019, 09:31 AM   #10
tomm.brz
Drives: brz 2017 hksv2
a stock PCV can leak and boost can go inside crankcase actually.... guess what's inside the crankcase?
Usually it's adviced to use a WRX PCV or a oneway check valve between the PCV and the intake manifold
Old 12-13-2019, 09:31 AM   #11
j_ros94
Lol thats what i said but not really sure and then when the tech said something else it made me doubt what i knew lol
Old 12-19-2019, 06:26 PM   #12
j_ros94
Update on my oil leak. It was coming from the oil pressure switch. Anyone wanna chime in to see if its an expensive cost or could easily be fixed at home kind of thing
Old 12-20-2019, 07:41 AM   #13
Halo_2
Drives: 2014 MY15 86 GTS
Halo_2 is offline   Reply With Quote
Old 12-20-2019, 08:27 AM   #14
tomm.brz
Do not even try to fix it, a new oil pressure switch is about 10 dollars from Toyota
Oil leak help please TorontoNat Engine, Exhaust, Transmission 1 12-26-2018 01:36 PM
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 04:28 PM
Oil Leak? Tofu-86 Forced Induction 3 09-23-2016 03:47 AM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 07:08 PM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 08:40 AM
