Drives: 2018 Toyota 86
How to add door courtesy light
You dont need to go through the door and tap into the dome light.
just tap into the wires in the door [ame="https://www.youtube.com/watch?v=SjTjz-eEiiA"]https://www.youtube.com/watch?v=SjTjz-eEiiA[/ame] |
| The Following 4 Users Say Thank You to hexxen For This Useful Post: |
MTXclusive
Drives: 2017 Toyota 86
What gauge wire did you use? also is it necessary to add an in-line fuse or no?
2017 Toyota 86 l Progress/Build/Update Thread
Jesus Christ dude, do you think you've shared this video enough yet?
| The Following User Says Thank You to Circa85 For This Useful Post: | soundman98 (12-16-2019) |
Drives: Scion FR-S
Drives: Scion FR-S 10 Series
THANK YOU for sharing this. This is exactly what I was looking for and I have not been able to find it anywhere!
#10 |
Drives: whiteout
This is awesome! I cant believe u were the first one to share this after the car has been out for so long!
I kept putting off this project bc I didn't want to run extra power wires through the door grommet. Just a small tip. I freaked out after doing this mod bc the window didn't automatically rolled up ~1inch after closing the door. (I disconnected battery before staring) Thought I blew a fuse, but wasn't. Just have to open the window all the way down, then all the way up so the window can reinitialze |
| The Following User Says Thank You to acuatlsfan For This Useful Post: | FRS_Ken (01-21-2020) |
| Tags |
| courtesy light, door light |
| BRZ Driver's Door Courtesy Light Won't Work | delusional | Issues | Warranty | Recalls / TSB | 31 | 05-29-2022 07:15 AM |
| LED Door Courtesy Light install | FRS2017 | DIY (Do-It-Yourself) Guides | 16 | 02-01-2022 11:00 AM |
| D.I.Y. - BRZ courtesy door light bulb change | joergasm | DIY (Do-It-Yourself) Guides | 24 | 09-13-2018 02:06 AM |
| Courtesy Door Light Help | Zero90 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 03-16-2014 08:53 AM |
| Passenger Door Courtesy Light Wont Turn Off | zex | Issues | Warranty | Recalls / TSB | 12 | 10-04-2013 01:31 PM |
