Old 03-15-2014, 07:52 AM   #1
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
Courtesy Door Light Help
I'm having an issue with my courtesy light door staying on. I just noticed it last night while driving as I couldn't tell what was so bright at the bottom of the door. I tried opening and closing the door several times incase it was slightly open but it still stayed on. I tried removing the LED bulb several times and changing it out with a new one and still had the same issue. Finally, I removed the negative battery terminal for about a minute to let everything reset and take away power and it was still there. Any thoughts or ideas that may help me troubleshoot this would be greatly appreciated!
PS. Haven't had the chance to test with normal bulb. My driver side light remains off as well as other LED components.
Zero90 is offline   Reply With Quote
Old 03-15-2014, 08:10 AM   #2
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Its a known problem. I have the same issue after going to LEDs. A BIU replacement is probably required, but take out the LEDs before you go to the dealership.
Here and here.
milhouse is offline   Reply With Quote
Old 03-15-2014, 11:12 PM   #3
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Agree with milhouse completely. After the warranty replaces the biu, make sure you unplug the light next time before switching the bulb...!
Jman1759 is offline   Reply With Quote
Old 03-15-2014, 11:33 PM   #4
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
or best unplug the battery. I unplugged the light from the harness, my BIU still fried ><
ucsmfu is offline   Reply With Quote
Old 03-15-2014, 11:49 PM   #5
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
See this thread:
http://www.ft86club.com/forums/showthread.php?t=60355
Basically what everyone else has said so far. Take the LED's out, take it to the dealership and have them replace the BIU. If you choose to put them back in after the BIU is fixed, disconnect the courtesy light assembly and DON'T use anything conductive (ex. screwdriver) to remove the light bulb! Doing this and then plugging it back in should save you from blowing the BIU. I've had my LED's in for around 7-8 months now and had no issues! Hope this helps and Good luck!
Husker BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Husker BRZ For This Useful Post:
Zero90 (03-16-2014), zex (03-16-2014)
Old 03-16-2014, 08:53 AM   #6
Zero90
Zero90's Avatar
Originally Posted by Husker BRZ View Post
See this thread:
Ill give it a try, thanks!
The Following User Says Thank You to Zero90 For This Useful Post:
Husker BRZ (03-16-2014)
Door Courtesy Lights on an FR-S: Basic DIY added boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 28 05-24-2024 01:42 PM
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 07:15 AM
D.I.Y. - BRZ courtesy door light bulb change joergasm DIY (Do-It-Yourself) Guides 24 09-13-2018 02:06 AM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 01:31 PM
