Old 11-29-2019, 01:17 PM   #1
solidsnake11
Drives: brz
more proof the #3 main bearing needs modified.
C
solidsnake11 is offline   Reply With Quote
Old 11-29-2019, 01:50 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You do know that element tuning documented this a long time ago when they first started building the FA. They have a few threads on here but they don't ever go into their solution as they say it is proprietary. They were making enough pressure to support 9k RPM boosted.
Old 11-29-2019, 02:14 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by solidsnake11 View Post
Please link where they show bearing modification. King bearing come with round holes.
Please link where they talk about beveling the oil gallery into the bearing groove.
Thanks ahead of time.
I have 90lbs of oil pressure at 8000rpm with 210f oil temperature I have enough for 9000 rpms just don't have cams to benefit turning that high.
As I said, they don't say what they did cause they claim it is proprietary. The title of your thread is "more proof that the #3 main needs modified." I am pointing out that this has been common knowledge for a while.
Old 11-29-2019, 02:16 PM   #4
PulsarBeeerz
Drives: JRSC BRZ SOLD
It is nice to have someone openly document everything they did to improve oiling for this motor.
PulsarBeeerz is offline   Reply With Quote
Old 11-29-2019, 02:18 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I agree, but why not add it to the thread he already has so it is in one place instead of creating another thread
http://www.ft86club.com/forums/showthread.php?t=131419
Old 11-29-2019, 02:26 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yeah. I'm not a fan of "shhhh... seeeecrets" I see exactly what you're talking about in that screen cap. If I were to go for any extra torque, my first step would be to reproduce your work. Thanks for sharing!
Old 11-29-2019, 02:28 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Because I think this is the biggest restriction to the oil that causes spun bearings in 2 3 and deserves its own thread.
That and this motor does not prioritize oiling the mains which compounds the issue.
Old 11-29-2019, 02:41 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine does. 8an to mains from oil filter. But like I said I think the bearing is the biggest issue.
I saw where your restricted flow to the heads(well, primarily the driver side) but not where that change was made.
Old 11-29-2019, 03:28 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's the title of the thread that illiceted my ****ish response. I read that and went, "no shit."
I appreciate all the info you have posted, at your own expense. My goals are significantly different than yours but along the same lines. I will be posting the teardown and buildup of mine once I have accumulated all the parts. Remember, work is not without criticism, and I expect a lot once I post up mine.
Old 11-30-2019, 12:15 AM   #10
Stomachbuzz
Drives: 2013 FRS
Can someone please explain what's going on here?
I have no idea what I'm looking at in the picture in the OP
Stomachbuzz is offline   Reply With Quote
Old 11-30-2019, 12:43 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
To simplify the above explanation. The crank rides on 5 main bearings. Main #1 feeds oil to rod #1. Main #3 feeds oil to rods 2 & 3. Main #5 feeds oil to rod number 4. So the idea is to improve the supply of oil to main #3 as those rods commonly spin bearings as the main has to feed two rods as opposed to the others just feeding one.
Last edited by NoHaveMSG; 11-30-2019 at 11:12 AM. Reason: corrected by solidsnake11
FRS main airbag G-Man Interior Parts (Incl. Lighting) 7 03-04-2019 09:04 PM
Main issues to look for when buying? PSim Issues | Warranty | Recalls / TSB 14 02-12-2018 11:12 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
Summit Main 9/14-9/15 fredk Mid-Atlantic 2 09-02-2013 11:59 AM
WTB Main Body ECU Acree Interior Parts (Incl. Lighting) 2 03-05-2013 05:31 PM
