Old 11-26-2019, 01:24 PM   #1
littlealex
Drives: cool
lowering without aftermarket rear control arms
hello everyone, i just got a set of tein flex z for my frs
just wondering will i need aftermarket rear lower control arms and camber bolts to adjust camber and toe if i lower it around 1.25"?
littlealex is offline   Reply With Quote
Old 11-26-2019, 01:26 PM   #2
StraightOuttaCanadaEh
Wes
I've been on aftermarket coils (~1.5" drop) for 3 years now, no LCAs, but I've also wondered if handling characteristics would be better with LCAs. But not enough to spend money on a potentially futile and expensive experiment
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
DarkPira7e (11-26-2019), Leonardo (11-26-2019)
Old 11-26-2019, 01:28 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Flex Z have camber plates in the front. So, camber bolts are not needed, but can work in conjunction. (I have both) Also, you don't need LCA, but if your natural camber is different on each side, you may want them. (mine was -1.8 LEFT and -2.2 RIGHT after lowering 1" - I have them now and my rear camber is the same on each side)
I LIKE TIRES!
Old 11-26-2019, 01:28 PM   #4
i8ur911
Drives: 17 BRZ Series.Yellow
Assuming you're looking at these for camber correction?
If so, I wouldn't worry about it. 1.25" isn't a massive drop.
The only time to be concerned with "too much negative camber" for a street car is when you get above -2.5* to -3.0*. Incorrect toe destroys tires much faster than camber.
When you do your alignment make sure the shop dials in factory toe specs and you'll be good to go.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 11-26-2019, 02:33 PM   #5
strat61caster
strat61caster's Avatar
Needed for driving around: absolutely not
Needed for perfect alignment: yes
ineedyourdiddly
Old 11-26-2019, 02:53 PM   #6
littlealex
Drives: cool
thanks for the inputs,
thats my daily car and i m looking for stock or close to stock alignment
i guess i dont need lca or camber bolt for 1.25"-1.5" drop
WTB Aftermarket Rear Lower Control Arms arkanist Want-To-Buy Requests 0 01-22-2019 01:16 PM
wanted: rear control arms, toe arms & trailing arms Turbo Canada Classifieds 0 08-14-2018 12:18 AM
Megan racing rear lower control arms , toe arms, rear traction arm fcdrifter20 Brakes, Suspension, Chassis 11 01-03-2016 08:11 PM
Effect of aftermarket rear control arms on toe protpibe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 06-26-2014 03:55 PM
