Drives: 2018 Toyota 86
header bolts
these are the bolts connected from the header to the overpipe, do other cars come with these no bead bolts? seems odd to me
![]() Sent from my iPhone using Tapatalk |
Drives: 17 BRZ Series.Yellow
Interesting.......
I don't remember mine looking like that (17 BRZ). Sent from my Pixel 3 using Tapatalk |
JDM Vaping Stance Nation
Drives: 2013 White
I just want to say those bolts were such a pain in the ass when installing aftermarket headers for me. I sprayed some lube oil in it and it didn't work. Not enough room for my impact driver. My breaker bar barely fit and it didn't even move it.
So I used oil + torch. It was still a tough job. The nut was seized on there still so the whole stud came off.
Clueless
Drives: 2005 Toyota Camry
it's a common bolt. one end threads into the flange on one side and the other side is held via a nut.
Nissan has had this for their catalytic converters for the last 30+ years. |
#6 | |
how the hell you take it out? i have the header out and it’s in the holes still, i’m hammering it out and lubed it but it’s not budging Sent from my iPhone using Tapatalk |
#7 | |
Drives: 2013 White
One side came out easily, just undid it with a breaker bar. The other side was the one I was struggling with. I ended up spraying a ton of penetrating lube on the bolt, wearing gloves I used one of those kitchen hand-held butane torches from my roommate and kept heating it. I think the heat made the penetrating lube go deeper into the flange and the heat loosen the stud a tiny bit. I used a breaker bar and kept pushing at it from underneath the car. In the end the Nut did not come off, I took the whole stud screw off with the nut still on.
Clueless
| Camber bolts or crash bolts for max spring perch clearance? | norcalpb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-29-2021 11:53 AM |
| OEM Camber Bolts (Crash Bolts - SU003-02818) | dieseldan444 | Brakes, Suspension, Chassis | 2 | 07-12-2018 09:06 PM |
| what are these 2 bolts I got in my ace header box? | Breadman | DIY (Do-It-Yourself) Guides | 6 | 05-21-2018 11:23 AM |
| Overpipe to Header Bolts/Nuts | 808BRZ | Engine, Exhaust, Transmission | 2 | 07-25-2016 08:41 AM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
