Drives: 2014 BRZ
Overpipe to Header Bolts/Nuts
Anyone know what size and grade bolt/nuts should I get for the connection of header to the overpipe? I just bought a used header and a used over pipe and neither have bolts/nuts.
#2 | |
Back-in-the-day we would just rummage around in the wooden boxes underneath the workshop bench till we found a couple that came close. HINT: If you found one that is perfect, don't waste your time looking for a matching one ...... it ain't there. humfrz |
...Just add nauseum
Drives: 2003 (AP1) S2000
Grade 8, M10 x 1.25 x 40mm bolts, and flange nuts (the ones with a wide base)
Use the OEM MLS gaskets with the crush ring. The graphite ones are useless. Use factory torque as a starting point, but remember you're using different materials, and the torque settings are no longer good. you may need to increase the torque significantly.
There are many ways to displace.
-Spartarus Last edited by Spartarus; 07-25-2016 at 09:33 AM. |
| Nuts for Subaru 14mm Crash Bolts | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-10-2016 12:44 AM |
| WTB: OFT, Overpipe, EL Header | Doobster | Want-To-Buy Requests | 1 | 08-20-2015 01:45 PM |
| New Rotor.New Nuts & Bolts? | Captain Snooze | Tracking / Autocross / HPDE / Drifting | 1 | 05-12-2014 01:10 PM |
| missing some nuts and bolts? | andrew5826 | BRZ First-Gen (2012+) — General Topics | 6 | 01-22-2014 02:03 PM |
| Header and Overpipe... | Scooby South | Engine, Exhaust, Transmission | 17 | 04-06-2013 08:35 AM |
