Old 11-17-2019, 04:31 PM   #1
jeschris45
Drives: Yellow FR-S Rs 1.0
Warm start issues with bigger injectors
I recently had id1050 injectors, warlboro 485, with delicious flex fuel kit installed on my car. I went through two different tuners and still cant figure why my car has problems when starting at warm start. The car cranks and fires then there is a massive rpm dip to sometimes 450 rpm. Sometimes it goes lower and stalls (not as often). I asked few folks and some have the issue and some don't. So not exactly sure whether this is an after effect of having bigger injectors or something is wrong with tuning/mechanical. Cold starts are absolutely fine and I have no problems with rpm dips or stalling.
Below is the video I was able to capture.
jeschris45 is offline   Reply With Quote
Old 11-17-2019, 04:59 PM   #2
tomm.brz
Drives: brz 2017 hksv2
You need to log this and upload it to datazap if you want help
tomm.brz is online now   Reply With Quote
The Following User Says Thank You to tomm.brz For This Useful Post:
Ultramaroon (11-17-2019)
Old 11-17-2019, 09:25 PM   #3
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
I solved same problem by zeroing out MAF correction after start (neutral) table .
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
steve99 (11-18-2019)
Old 11-18-2019, 05:17 AM   #4
tomm.brz
I dont know, shouldn t the first 2 rows active during cols start? He said cold start is good
Yobiwan (11-18-2019)
Old 11-18-2019, 08:20 AM   #5
jeschris45
Adding the log file to the issue.
https://datazap.me/u/jeschris45/hot-...?log=0&data=30
Old 11-18-2019, 08:24 AM   #6
Yobiwan
Yobiwan's Avatar
I don't know exactly why.
maybe zeroing out middle section (warm temperature area ) will be enough for effect. but I didn't test that.
Old 11-25-2019, 10:54 PM   #7
Yobiwan
Yobiwan's Avatar
oops. sorry.I was wrong. zeroing didn't solved issues.
adding the numbers of specific temerature range solved problem.
tomm.brz (11-26-2019)
help!! can’t get car to start with bigger injectors Kalebhall Software Tuning 15 02-17-2020 07:22 PM
WTB: Bigger Injectors, Fuel Pump & Flex Fuel Kit spagti Want-To-Buy Requests 4 04-13-2019 04:33 PM
ECU reset + warm start = stall phrosty Issues | Warranty | Recalls / TSB 3 04-08-2018 07:31 AM
Bigger injectors ecutek aquaman Software Tuning 2 04-05-2017 02:15 PM
E85 issues with injectors? CaptainSlow Software Tuning 66 07-31-2016 11:47 AM
