ECU reset + warm start = stall
Hi guys, noticing a weird thing happening when I start the car after I reset the ECU -- disconnecting battery, flashing a tune, etc.
If the engine is warm, it'll stall out. I need to give it some revs to keep it alive, and get into gear at higher than idle revs or it'll die. Once it's in gear it's good to go. If the engine is cold, it starts up and after the initial high RPM it dips down nice and low, not enough to sputter but enough that DRLs will dim out, and then recovers. My assumption is that the cold start routine is giving extra fuel and thus preventing the stall. After I get it moving, lifting off the accelerator will cause a similar RPM dip as the cold start bit. Either way, after a few minutes of driving the car appears to calibrate and has no trouble starting up after that, warm or cold, and no RPM dip. Any ideas to the cause or how to diagnose? I don't believe it to be a leak as fuel trims are spot-on, and I hear nothing out of the ordinary. It drives otherwise normally.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#2 | |
I suggest you turn the idle screw a half turn clockwise...... ![]() (yep, it used to be just that simple) Seriously, maybe a tuner should take a look at it ..... or, drive it for a while to see it will re-learn the idle setting.humfrz |
#3 | |
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
Check maf offset after start tables
Check ltft at idle after car as idled for 5 minutes if its high ie over 10% likely maf scaling needs work or you got some sort of exhaust or intake leak. also look at afr at idle should be around 14.7 idle vacuum should be around -20in Hg or -9psi |
| VDC AND CEL AFTER STALL? | AdrianJ05 | BRZ First-Gen (2012+) — General Topics | 1 | 08-18-2015 03:23 PM |
| Stall on startup? | Mhenderson | Software Tuning | 3 | 06-28-2014 04:27 PM |
| Stall/Torque Converter | DeOppressorLiber | Engine, Exhaust, Transmission | 44 | 06-12-2014 12:00 PM |
| Engine cut out/stall followed by CEL | vanetix | Issues | Warranty | Recalls / TSB | 4 | 01-16-2014 11:51 AM |
| Partial Stall's WRB | Partial Stall | Member's Car Journals | 3 | 06-07-2012 06:53 PM |
