Drives: 2014 FR-S
Time for a built bottom end need advice
Hey all,
So i was debating buying a supra, and i have decided I am just not done with this platform. I have some money set aside and I am looking for more power. Current setup JRSC, JDL Headers, JS Oil Cooler, exhaust... Im looking for more HP.. Looking for north of 400whp. I would not mind staying with JSRC and moving to RS pulley and E85 in the future. That said im paranoid about adding any more power to the stock bottom end. First and foremost not looking to swap with anything, not trying to 2J or LS here just looking for the 4-500 HP range. I am looking at built bottom ends, Crawford... MAP... IAG.. have a few questions.. First off anyone have any experience with any of them? or any other commendations? Second, with my HP goals in mind i would like to run stock heads.. trying keep the budget in check and hoping I can achieve my goals on stock heads. Is this possible? I understand the limitations of the JRSC and may look to turbo in the future but currently looking to see what it can do. Located in Nor Cal so if anyone has recommendation of local engine builders i would also be interested. |
| The Following User Says Thank You to GenRuleAThumb For This Useful Post: | DarkPira7e (11-17-2019) |
What gearbox solution you going with?
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following 3 Users Say Thank You to 86MLR For This Useful Post: |
Drives: 2014 FR-S
Rust bucket enthusiast
Only limitation on stock heads are the valve springs- I'd run stock unless you have an issue. I would go with the MAP engine. I've been seeing several failures in IAG EJ25 blocks that start having ring blowby within a few weeks. Can't find any dirt on them online, but that doesn't mean it's not there. IAG used to be my recommendation, but with the issue consistently being rings, I feel like their machining work is sloppy
pessimistic skeptic
I would reduce compression with RS pulley if you are going to daily drive and want to use 93 octane. Tune can be better optimized with lower compression and higher boost.
Drives: 2013 Turbo FRS
I am looking to build my motor as well, although looking for reliability for around 300-400 hp.
I currently have the JDL Precision 4854 kit producing around 330 to wheels. I am looking at AIG, Rev Works, Element Tuning and Titan Motorsports. I Rather have a shop close to me since I live in Orlando and Rev Works and Titan are here. |
Bluemoon Performance would be my go-to for an engine. You get what you pay for.
You'll likely need more than just a bottom end to clear 400whp with a JRSC. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Tristor (12-24-2019) |
With 400whp you better stock up on transmissions. Turbo would be my choice for that level of power. Less PSI needed and you could so some tricks with limiting boost per gear and help reduce wtq in the lower rpms
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Tristor (12-24-2019) |
Drives: 13' Brz
a sc makes significantly less tq than a turbo. so, at 400whp with a sc would be fine on the transmission. tq kills transmission, not hp.
#10 | |
even at 400 whp would only put him at what 330wtq ish. The more 4th gear pulls the more likely of sheering that gear. Friend who has a e85 boosted has killed 3 trans but he is closer to 425 to 450whpSent from my GM1915 using Tapatalk
| Blown engine. Built time? | Theratt1 | Engine, Exhaust, Transmission | 19 | 02-28-2016 12:41 AM |
| CA FS: Fully built street and time attack 07 Amuse S2000 | Ricky Kwan | Cars for Sale/Trade | 2 | 05-15-2015 02:09 PM |
| First time FR-S buyer looking for advice! | Panku | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 08-30-2014 11:10 PM |
| Slight body damage, bottom side below passenger door. Need advice! | FR-S Matt | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 12 | 01-23-2014 09:40 PM |
| ****ADvice REquired: Built/vs/Stock*** | killerkid08 | Forced Induction | 54 | 06-09-2013 05:57 PM |
