Drives: Toyota 86
What wire turns on the rear amp?
I'm installing an Android that came with the Toyota Harness but it doesn't turn on the amp for the door speakers.
Looks like one wire is missing from the 6 pin and I suspect that is it. Looks like there are lots of threads about this but I'm just not getting it... |
#2 | |
Drives: 2019 Toyota 86 TRD SE
6-pin connector on back of radio: Pin 1: Yellow = right rear speaker positive Pin 2: Purple = left rear speaker positive Pin 3: Black = right rear speaker negative Pin 4: Unused Pin 5: Black with white stripe = Illumination Pin 6: Pink = left rear speaker negative 10-pin connector on back of radio: Pin 1: White with blue stripe = front right speaker positive Pin 2: Black = front left speaker positive Pin 3: Red = Accessory switched 12V Pin 4: Orange = Battery constant 12V Pin 5: Black with blue stripe = front right speaker negative Pin 6: Yellow = front left speaker negative Pin 7: Black/blue = Ground Pin 8: Unused Pin 9: Brown = Factory amp turn on Pin 10: Purple = Illumination Knowing this might help you sort out your problem. Good luck! Last edited by OsageJJ; 11-16-2019 at 11:59 PM. |
Drives: Toyota 86
| handbrake wire and reverse wire location Australia gt86 | rsingh | Electronics | Audio | NAV | Infotainment | 0 | 01-16-2017 09:12 PM |
| Rear Speaker Wire Question | Kaotic Lazagna | Electronics | Audio | NAV | Infotainment | 2 | 01-01-2016 01:54 AM |
| Vibration on hard right turns | ravisraval | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 10-22-2015 09:33 AM |
| Help me identify this wire! Extra wire around battery after clutch job | YouShallKnow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 12-09-2014 02:04 PM |
| Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 10:22 AM |
