Old 11-16-2019, 05:21 PM   #1
Texascat
Drives: Toyota 86
What wire turns on the rear amp?
I'm installing an Android that came with the Toyota Harness but it doesn't turn on the amp for the door speakers.
Looks like one wire is missing from the 6 pin and I suspect that is it.
Looks like there are lots of threads about this but I'm just not getting it...
Texascat is offline   Reply With Quote
Old 11-16-2019, 08:41 PM   #2
OsageJJ
OsageJJ's Avatar
Drives: 2019 Toyota 86 TRD SE
Here's what's on the 6- and 10-pin radio harnesses in my 86:
6-pin connector on back of radio:
Pin 1: Yellow = right rear speaker positive
Pin 2: Purple = left rear speaker positive
Pin 3: Black = right rear speaker negative
Pin 4: Unused
Pin 5: Black with white stripe = Illumination
Pin 6: Pink = left rear speaker negative
10-pin connector on back of radio:
Pin 1: White with blue stripe = front right speaker positive
Pin 2: Black = front left speaker positive
Pin 3: Red = Accessory switched 12V
Pin 4: Orange = Battery constant 12V
Pin 5: Black with blue stripe = front right speaker negative
Pin 6: Yellow = front left speaker negative
Pin 7: Black/blue = Ground
Pin 8: Unused
Pin 9: Brown = Factory amp turn on
Pin 10: Purple = Illumination
Knowing this might help you sort out your problem. Good luck!
OsageJJ is offline   Reply With Quote
Old 11-17-2019, 12:57 PM   #3
Texascat
Drives: Toyota 86
Thank You, that made me notice the Toyota harness that came with the radio was missing the turn on wire.
All working now.
handbrake wire and reverse wire location Australia gt86 rsingh Electronics | Audio | NAV | Infotainment 0 01-16-2017 09:12 PM
Rear Speaker Wire Question Kaotic Lazagna Electronics | Audio | NAV | Infotainment 2 01-01-2016 01:54 AM
Vibration on hard right turns ravisraval Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 10-22-2015 09:33 AM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
