Drives: 13 CSB BRZ Ltd
Front Control Arm Bushings Flawed - Rear Bushing
Intro:
I'm making this post to get feedback from the community. I cannot be the only person out there who has noticed this or had this problem. I recently started working with a well known coilover company to test and provide feedback for their upcoming product line. Information on that will be released when the company deems fit. The Problem: The front control arm rear inner bushing is compromised. The control arm sits as far back towards the rear of the car as possible. This means that the bolt going through the front bushing is pointed toward the rear of the car and outward, instead of straight down like it should be. I unfortunately did not take pictures of this the last time the car was on the lift, but I will Friday. How can you tell? The front wheels sit further back in the wheel well instead of being right in the center of the well. It's visibly noticeable on my car, especially since the car was lowered and I'm still on stock wheels. After the alignment, the car measured 4.5/4.6* caster. Stock is 5.5/5.6. If you are able to get up under the car, the bushing looks like you roasted a marshmallow on a stick, and then pulled it off the stick. The same "gooey" looking center is what the center of the bushing looks like. Misc My car has 17k miles on it and one track day. There is absolutely zero reason for the bushing to be compromised like it is. I will have a picture as soon as I can and post it up in this thread. |
Bumping this up...
The Answer
Drives: Mazda 2
So did the bushing melt? How low did you drop the car?
any noise related to the bushing being failed? i have a clunking noise coming from the suspension (not sure where) whenever i hit even a small bump, it's either a blown strut or a bushing....
FIVE AXIS DESIGN http://www.fivead.net (FIVE:AD Edition Ultramarine FR-S)
VTR http://vtrweb.com/ (Reccomended Pacific NW Shop!) [CLOSED] AVO Turbo http://www.avoturboworld.com (Great Products for a Great Price!) |
Cognite
Drives: 2013 Whiteout FRS
innnnnnteradasting... post updates plz
No noise that I have noticed related to the bushing. But again I have coilovers and track pads on the car.
Thanks
Curious on the pics?
Going to be working on some maintenance next month, would check mine. Stock but have 20k miles. |
#9 | |
Drives: 2020 GMC Canyon Denali Diesel
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#10 |
The Answer
Drives: Mazda 2
If it's the front bushings your talking about (your post mentions both, a bit confusing) then you can easily take a picture off lift with the wheels turned
I checked my bushing following this and they look like new. The rear are harder to inspect but I got no symptoms of shot bushings.
| White line KCA434 front lower control arm bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-02-2015 12:37 PM |
| Front Control Arm Bushings. | feldy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-02-2013 05:35 AM |
| *NEW* Scion FR-S Front and Rear Carrier/Stay Bushings | TWM Performance | TWMPerformance | Transmission and Driveline | 0 | 02-25-2013 05:31 PM |
| WORKS Rear Upper Control Arm Bushing - Inner Camber Correction | 86_ZN6 | Brakes, Suspension, Chassis | 0 | 02-06-2013 12:20 AM |
