FR-S Owner!
Drives: 2013 FR-S Ultramarine 6AT
Installing Dynamat on doors: OK to leave the black glue?
I am attempting to install Dynamat for the first time in my doors, and I removed the plastic moisture barrier per the instructions, but the adhesive left on the door is so soft and sticky that it's a pain in the ass to try and remove. The more I try to scrub it off (after using some adhesive remover) the more it seems that I'm just spreading it around. Is it OK to just put the Dynamat over the adhesive?
Drives: 2013 FR-S Matte Orange
Yup, just leave it. Butyl sticks to everything and so does dynamat.
FR-S Owner!
:happy0180: Thanks!
Drives: 2015 BRZ/ Blue Series/ WRB
Let us know if it takes away that terrible rattle of too much bass.
2013 SWP BRZ #137 First BRZ in Columbus, OH! SOLD
2015 WRB Blue Series #900/1000 Team Rowdy Ohio Native Instgram brooks_church |
FR-S Owner!
HUGE DIFFERENCE!!!
I did some selective Dynamat around the speakers in the doors and now that all the rattles keep popping up I will be adding a full job to my to do list.
Drives: 2013 Subaru BRZ Limited in WRB
I just did this on my BRZ and the doors are now rock solid. Next up is that rattling rear
Drives: 2013 Subaru BRZ Limited AT
Are there any instructions for doing a full dynamat on a brz?
Instructions
Strip everything out that bolts or snaps in place Place Dynamat on metal Reinstall everything that bolts or snaps in place
#10 |
#11 |
#1362
Drives: 2014 Ice Silver WRX
can you link what you ordered? i've been looking at this:
Dynamat Xtreme Door Kit 10435 Xtreme Door Sound Dampening Kit with Four 12" x 36" Pieces http://www.newegg.com/Product/Produc...9SIA15Y0AE3155 would that be enough?
#12 | |
Drives: 2013 Scion FR-S White Out
I was planning on just putting dynamat around the speakers and some on the outer door skin. Then installing dynaliner over the doors between the inner door skin and the door panel. That should kill the rattles and help the audio quality a bit shouldn't it? |
#13 |
Drives: 13 DGM BRZ Ltd
Guys, guys, guys!
Dynamat is just a brand name product for CLD. If you are buying Dynamat, I sincerely hope you have considered at least one of the handful of other brands out there that perform the same as, if not better than, Dynamat for a (sometimes MUCH) lower price. |
#14 | |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
The 25ft^2 should be enough to make a difference.... installed in the two doors, the trunk lid, and some light use under the spare tire... it really all depends on how much weight you want to add to a light sports car. For the doors, I have about 30% coverage on the outer skin, and 30% coverage on the inner skin (focused around the 6.5" woofer). Websites on this stuff says the important thing (besides eliminating rattles) is to separate the air from the front of the woofer from the air behind the speaker. That's why I bought some "For Rent" signs and duct-taped the few holes that exist on the inner skin. I'm still looking for something similar to Dynaliner for between the inner skin and the door card. Be careful not to overdo the trunk liner or else the auto trunk release may not open the trunk cause its too heavy. Make sure you also take care of the rear license plate/frame cause that is a very common source of rattles. Here's a "work-in-progress" photo from Saturday.... I can post some more of the finished product later. |
| 86 with Lamborghini Doors | quik1987 | Cosmetic Modification (Interior/Exterior/Lighting) | 102 | 04-10-2018 09:32 PM |
| lambo doors. What you think? | FLIPs_FR-S | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 04-10-2018 09:13 PM |
| Installing a Galaxy Nexus ? Ideas ? | miodculae | Electronics | Audio | NAV | Infotainment | 12 | 07-20-2012 03:36 PM |
| I'll Just Leave This Here. | Asterisked Accolade | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 06-11-2012 08:59 PM |
