Software Hobbiest
Drives: 2015 FRS
So i have done some modification to my engine
Nameless Cam Plateand im currently running the E85 tune supplied by OFT. My car runs amazing after warm but cold starts in the morning take 3-5 attempts every morning. I have already replaced the coolant temp sensor. I emailed Manley and asked if the pistons needed a custom tune and they said no. I dont know what else to check tho? Any Ideas??? |
Drives: 2013 brz limited / galaxy blue
Maybe running e85 on a stock fuel pump could be the culprit
Drives: Tornato grey 86
A cold start is always going to be harder on E85, even harder if its cold out.
Drives: 2017 toyota 86
You should really use flex fuel with E85 for various reasons, but
you can fix cold start issues for the most part. http://www.ft86club.com/forums/showthread.php?t=67310 read this thread it shows the changes needed in tune. |
Software Hobbiest
Drives: 2015 FRS
Ill try the tune update. Thank you for the replys
Software Hobbiest
Drives: 2015 FRS
UPDATE
The tune failed to start the car Reverting back to the base E85 tune supplied by oft Any other ideas |
EcuTek?
Software Hobbiest
Drives: 2015 FRS
Here is my current tune file that failed and an image of what i changed off of the stock OFT-Stage2-E85 tune.
Tomorrow i plan on going through the whole intake to check for vacuum leaks |
Software Hobbiest
Drives: 2015 FRS
I am using OFT 2.0 with RomRaider V0.5.9RC3
#10 |
Hi message me should be avle to get you starting down to about 32F or 0c first crank on 80% plis ethanol amd a bit lower on say 70% stuff
Your definiton is also incorrect note the tavle that has 32 in entire row thats no good. Also you need to alter all the crank tables and the rpm vs temp crank table |
#11 | |
Just needs cranking tables altered |
#12 |
Software Hobbiest
Drives: 2015 FRS
If you look at the numbers up top of table F all the temp ranges are the same. Also noted I did a data log this morning for first start and noted that the LTFT is at 16% on start and floats down to around 7% hot.
My guess is that the intake isn't seated to the block correctly, Im also going to plug in a scan tool and read the O2 sensors to see if they got damaged during the engine build. |
#13 |
Software Hobbiest
Drives: 2015 FRS
Update:
I have since tightened all of the intake bolts and clamps Put a new battery in the car also Car starts right up on cold but dies right after still till the third crank attempt every cold start. Doesn't matter if its cold out or warm out, its usually after the car has been sitting for a while. Starting to wonder if I have an injector leaking? |
#14 |
Software Hobbiest
Drives: 2015 FRS
Turns out, when i put the stock back on the car.
The car no longer runs lean. So I either need to leave the exhaust restrictive or put the aftermarket back on and get a tune. |
| Tags |
| built engine, cold start, idle |
| Cold start pop | Ash3482 | Engine, Exhaust, Transmission | 3 | 03-07-2019 07:39 PM |
| Electrical Problems - Car Won't Start | dutchdabomb | Issues | Warranty | Recalls / TSB | 11 | 03-21-2015 12:41 PM |
| EcuTek SD problems in the cold | zkv476 | Software Tuning | 16 | 02-12-2015 04:26 PM |
| E85 cold start | Turdinator | Software Tuning | 8 | 08-29-2014 11:12 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
