Drives: Toyota gt86 my19
Rattle rear trunk
Sorry guys i used Google traslator
Hello I've heard a rattle lately in the back, it seems to come from the right side, at least it is with the easiest hearing you have since the driver's headrest doesn't cover it. It sounds like plastic vibrating and not metallic as I have read in one of the posts that identify a rattle that is the wireless box. if you hit the 2 isofix caps it vibrates and if you hit the brake light too. The idea would be to paste some foamy material to try, but before doing anything I wanted to know your experiences and what you did. I also have rattles when I play loud music, this is more normal since I have the oem audio plus system installed, but do the vibrations really come from the isofix covers or the brake light? Maybe they are already plastics to be soundproofed. That is why I ask for your experience if you have had any of these problems and what tricks you use to find or solve them. Thank you |
Drives: 2013 Scion FRS white
The FRS is not a great car in terms of sound deadening. My suggestion would be to apply some sound deadening material such as Dynamat, etc. I recommending finding some off brands since Dynamat is very expensive and could cost you hundreds to do the trunk or a good portion of the car. Apply as much as you can to the trunk, but the priority is going to be the trunk lid itself. You simply remove the carpeting or whatever and apply the sticky material directly to the frame/metal in the car.
22R
Drives: 2012 Camry SE 2017 Toyota 86
| Rear trunk area rattle from flapper box..What is it ? | 22R | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 12-17-2018 10:17 PM |
| License plate trunk rattle | toast | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 02-18-2017 04:07 PM |
| Rear Deck Rattle | zuko | Issues | Warranty | Recalls / TSB | 23 | 06-28-2016 11:59 AM |
| Rattle in rear left of car - Need some help! | eleu2166 | AUSTRALIA | 4 | 12-01-2012 10:51 AM |
| do you think the rear deck rattle... | pr086 | Issues | Warranty | Recalls / TSB | 7 | 08-03-2012 05:35 PM |
