Drives: scion fr-s
Frs 2016 white smoke/burning smell
i changed my cam plate but it still has a smell and it smokes a lot more?
#2 |
Drives: 2013 FR-S Series 10
you need to be more specific.
i put in about as much effort into my reply as you did your post.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#3 |
White smoke=coolant
Blue smoke=oil Black smoke=Fuel as stated above more info needed!!!!!!!!!!!!!!!!!! |
#4 | |
![]() Are you sure it was the old cam plate that was leaking? Did you replace it with an aftermarket plate? Did you follow the installation instructions carefully? Did you lightly oil the "O" ring before bolting on the plate? Did you use some sort of sealant? Did you clean up all the old leaked oil off the exhaust pieces? Talk to us. humfrz |
#5 | |
Drives: scion fr-s
yes i cleaned everything and no oil is coming down anymore but there is still white smoke coming out and the smell Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to uhnexo For This Useful Post: | humfrz (10-04-2019) |
#6 |
Drives: scion fr-s
#7 |
#8 |
The Dictater
Drives: '13 Red Scion FRS
That's funny, I thought only the BRZs had the built-in vape...
#9 |
Figure out where the coolant is getting into the combustion chamber and fix it. I do not know all the areas where this can happen on a FA20 but most likely culprit on most engines is the head gasket.
#10 |
Rust bucket enthusiast
Why not bring it into a shop to have them pressure test your cooling system? This will tell you if there's a leak externally or internally.
I see you're in Vegas, but it is worth mentioning that the nights are getting cooler. What have the temperatures been when you're seeing this? Could be normal operation steam if you're seeing temps at or below 50f. |
#12 |
#13 |
Check your oil and see if it looks milky. If it does, coolant is getting in there. Like the guy above stated, head gasket.
#14 |
Washer fluid? Completely ran out? The "smoke" isn't steam from a leaky washer fluid canister? Seems pretty straightforward doesn't it?
| Burning smell and white smoke | Tacticalpanda | Issues | Warranty | Recalls / TSB | 22 | 09-04-2024 08:18 AM |
| '17 BRZ burning smell | Zoh | Issues | Warranty | Recalls / TSB | 28 | 05-14-2017 11:09 PM |
| Burning smell | Riftur | Engine, Exhaust, Transmission | 9 | 04-13-2016 01:50 AM |
| White smoke, burning smell, puddle of brown fluid leaking. | driftking96 | Engine, Exhaust, Transmission | 5 | 02-20-2016 01:54 AM |
| Smoke and burning rubber smell | JayDee | Other Vehicles & General Automotive Discussions | 7 | 03-15-2014 10:25 PM |
