Drives: 2013 subaru brz
Do I need new sway bar links ?? To fix this issue ??
Hello, I bought 2013 brz with Sure motorsports coilovers around 3 years ago.
Recently I started hearing noise coming from suspension (sound like something is loose, hear it over bumps going slowly) , my mechanic told me that I need new sway bar links, he doesn’t know where to order these because they are not OEM Do you have to install different length sway bar links if you have coilovers ?? Where do I get them ? How do I can check what do I have ? I’ll be selling brz and want to fix it before, thank you for help |
Drives: Crapcan
Depends on how much lower you are over stock but 1 inch or more you should probably buy adjustable endlinks. Otherwise you end up with rubbing issues.
I’m sorry it was stance coilovers
The Gunshine State
Drives: '14 BRZ Limited
Check out Whiteline adj endlinks, my set has been great.
![]() Current DD: M235i |
| Need help with OEM sway-bar end links | chipmunk | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 12-07-2019 05:48 PM |
| End links for TRD sway bars | Shindobaddo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-29-2019 03:28 PM |
| Help with sway bar end links | MisterSheep | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 09-29-2015 11:02 AM |
| WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 01:20 PM |
| Need help! coilovers/sway links issue | P_say86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 03-19-2015 08:35 PM |
