Old 09-13-2019, 08:55 PM   #1
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Post DIY - Installing Dasaita MAX6 unit on '17 BRZ w/Backup camera, Aux In, and USB
This guide is for the DASAITA unit, which I can confirm has a different black power connector pin-out than the Joying Akuma installed in his car.
The Basics
Out of the box, almost everything works with this this Dasaita stereo. The Steering Wheel Controls (SWC), GPS, Bluetooth, WiFi, and radio all work flawlessly. However, a few things do not: the front door speakers+factory AMP, the backup camera, the front USB and the auxiliary input all do not work out of the box. However, they are pretty simple to fix once you learn how to do it.
When ordering your unit, ask for the Toyota Dasaita harness. It should come with both a 24 and 28-pin connector in the harness, but specify which connector you want just in case.
To start, you will need a few tools and supplies. Get them before you start with the project:
  • Soldering iron
  • Rosin core 60/40 leaded solder
  • Heat shrink tubing
  • Wire cutters/strippers
  • Helping hands
  • Heat gun/hair blower
  • Zip ties
  • Box cutter
  • Small box fan
  • Dust/gas mask
  • Sharpie
  • Old used wet sponge
*Alternatively, you can use butt connectors. But they are crap and will give you problems down the line. Also, work in a ventilated area -- solder fumes are no joke.
Additionally, you will need:
  • Precision screwdrivers set
  • Regular screwdrivers
  • Panel safe removal tool set
  • Wrench set and 10mm socket
  • Headlamp
  • AX-SUB28SWC-6V - for backup camera RCA, aux RCA, and a few other cables you are gonna steal from this connector.
  • 12V to 6V DROK car power converter
  • AX-SUBUSB2 usb headunit adapter
  • DASAITA MAX6 toyota headunit
  • Elbow grease
Now that we have everything, organize everything in your workbench, put some chill music, and open the Dasaita box. We are gonna need the main harness, the AX-SUB28SWC, the DROK converter, and the soldering supplies.
The main harness has the 10+6 pin connectors, a 24 and a 28-pin connector, a radio antenna connector (identical to metra 40-LX11), a reverse orange cable, and a brown parking brake cable. We will use all of these except the 24-pin and the brake cables.
The 24 and 28-pin cables are only wired for SWC out of the box, so we have to add a few cables to the 28-pin connector and this will be half of the job, the rest will be soldering these to the main harness.
Part A - Repinning
Grab the AX-SUB28SWC and a tiny flat-head precision screwdriver, like the ones for fixing glasses. I used a 1.4mm, but it barely fits in the hole and a smaller one should work better. Insert the flat head in the dash (-) shaped hole, and press with all your might. You might need some kitchen paper tissues to hold the connector in one hand and the tiny screwdriver on your other hand without bruising your skin. Remove the following pins:
  • Pin 2: Reverse trigger, green wire
  • Pin 11: Camera power (+6V), red wire on mine, yellow on Akuma's
  • Pin 12: Camera +, yellow wire
  • Pin 13: Camera -, black wire
  • Pin 15 >>> 9: Blue parking brake wire, INSERT ON PIN 9 of dasaita 28-pin connector!
  • Pin 20: Camera power ground, black
  • Pin 21, 22, 23: SWC, should already be installed on Dasaita harness! No need to remove.
  • Pin 26, 27, 28: AUX IN, red, black, and white respectively.
Now that you gave your hand blisters and you cursed like a sailor, insert all of these pins back into the DASAITA 28-pin connector. All of them should be in the same pin slot #, except for blue parking brake wire which should be inserted in pin 9 and will now work for AMP SIGNAL (12V), and will power the factory Amp and the front door speakers.
Part B - Cutting and Soldering
We are almost done. We need to solder our cables together and you will have a custom-made plug-and-play harness for your shiny new Dasaita unit. We will solder about 5 solder joints as follows:
  1. Solder the blue+pink stripe wire, Pin 9 of 28-pin connector into blue wire, pin-13 of black 20-pin connector. Cut blue wire 1 1/2" away from black connector, splice the long end of pin-13 wire with pin-9 wire, then solder these two with the shorter end close to the black connector. This powers the factory car AMP with the headunit's 12V.
  2. Solder the black wire from pin 20 of 28-pin connector with the black wire from the 6V (yellow) side of the DROK converter.
  3. Solder the red wire from pin 11 to the yellow 6V wire of the DROK converter.
  4. Splice the green wire from pin 2 with the red 12V wire of the DROK converter, then solder these two with the orange REVERSE wire of the Dasaita harness (pin 2 of the black connector).
  5. Solder the black wire from the 12V (red side) of the DROK converter with the ground loom of the dasaita harness (pin 15 of the black connector). I cut the loom where the wires meet, then spliced the four black wires together and soldered them with the black ground wire in pin 15 of the black connector, but this was a royal pain in the ass to solder. If I could do it all over again, I would just cut one of the black thin wires and solder my black DROK wire to it, but what's done is done. Your choice.
The Finished Product
Important: for all of these, remember to put a shrink tube as far away from the solder joint as possible. After soldering, slide the tube on top of the joint and use the heat gun to shrink wrap it. Please be very careful when soldering as you can shrink the tube prematurely with the heat of the iron and the result is a PITA to fix. Before cutting them, join all the relevant wires together and tape them if you want an idea of where everything will go. Measure twice, mark with a sharpie, and cut once. Finally, I strongly suggest practicing a few solder joints with the excess cables you get or cut. This made a huge difference for me.
That is all, you should have a fully functional plug-and-play dasaita harness. The last thing is to plug in the adapter (D) into the headunit to get aux In and backup camera Input, the (B) and (F) cables for two additional USB ports, the AX-SUBUSB2 to get front USB, and the GPS and WIFI antennas for their respective uses. Also included is a USB SD card+adapter with GPS data for the native GPS app, so plug that in if you want, and an external mic which I'm too busy and too lazy to route at the moment. When removing or connecting the stereo, remove the black terminal of the battery to be safe.
edit: Please connect and route the external mic to the front of the speedometer/back of the steering wheel, it makes a huge difference as the internal HU mic is garbage. The external mic works wonderfully.
Plumbus is offline   Reply With Quote
Old 09-13-2019, 08:55 PM   #2
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Image references
Stock dasaita harness
Axxess AX-SUB28SWC-6V
28-pin connector
Solders
Black connector wiring diagram
Old 09-13-2019, 08:56 PM   #3
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Notes
Tutorials:
DIY - Aftermarket Head Unit install on 2017 BRZ - MASTER GUIDE by akuma
https://www.ft86club.com/forums/showthread.php?t=111866
Knowledge base:
Complete BRZ install information guide - EXTREMELY useful - thriller
https://www.ft86club.com/forums/showthread.php?t=128374
2012-2013 WRX/STI wiring pinouts
https://forums.nasioc.com/forums/sho...28&postcount=9
BRZ 28-pin connector pinout diagram - super useful
http://www.ft86club.com/forums/showp...1&postcount=22
note: amp signal has been moved from 10-pin connector/pin 8 to 28-pin connector/pin 9. Pin 8 on 10-pin connector is now antenna on new BRZs.
24-pin backup camera pinout (FRS) and FRS/86 reverse camera fix. Not for BRZ
http://www.ft86club.com/forums/showp...3&postcount=77
http://www.ft86club.com/forums/showt...=111866&page=6
USB port Retention cable types v1 and v2
http://www.ft86club.com/forums/showthread.php?t=128369
AE64 Headunit harness info website, very useful, though may be a bit outdated for facelift year cars
http://ae64.com/aftermarket-HU-install-parts-2012FT.htm
http://ae64.com/28-pin-aux-harness-FT.htm
http://ae64.com/aftermarket-HU-install-parts-index.htm
Subaru BRZ audio overview
https://www.crutchfield.com/S-tw8QtU...ubaru-brz.html
How to solder like a 1970's engineer
[ame]https://www.youtube.com/watch?v=vIT4ra6Mo0s[/ame]
How to solder like Chrisfix
[ame]https://www.youtube.com/watch?v=Zu3TYBs65FM[/ame]
Headunits
Dasaita MAX6 PX6 with Toyota 200mm wide double din
https://www.aliexpress.com/item/33015117019.html
Dasaita MAX6 PX6 with Universal 180mm wide double din
https://www.aliexpress.com/item/33010915960.html
Dasaita PX5 4gb+32gb with Toyota 200mm wide double din
https://www.aliexpress.com/item/32851069278.html
Dasaita PX5 4gb+32gb with Universal 180mm wide double din
https://www.aliexpress.com/item/32849372728.html
Seicane android 9.0 4g+32g toyota din
https://www.seicane.com/seicane-s126...earview-camera
https://www.seicane.com/in-dash-car-...for-toyota?p=6
Tools, harnesses, and misc:
Panel removal tool set
https://www.gtacarkits.com/product/p...oval-tool-set/
Subaru BRZ:
Joying toyota HILUX harness
Please see ft86 section below for link! For joying only!
Axxess AX-SUB28SWC-6V -- 28-pin harness w/backup camera RCA
https://www.crutchfield.com/S-nSXghC...B28SWC-6V.html
https://www.amazon.com/Axxess-AX-SUB...dp/B01E4FCW2U/
https://audiojamonline.com/axxess-ax...ontrol-harness
note: 28-pin connector includes yellow RCA cable for backup camera for 2017+ BRZ. also includes 12v to 6v converter, but it's junk. get the DROK converter instead. For FRS/86 get TOYCAM3 and DROK. Standalone SUB28SWC harness without 6v converter has been mysteriously discontinued.
Axxess AX-SUBUSB2 USB Retention Harness for Select 2015-Up Subaru Vehicles
https://www.amazon.com/Axxess-AX-SUB.../dp/B01DJ4KVQ6
note: Use this for BRZ 2016+. For BRZ 2013-2015, get AX-SUBUSB. For FRS and 86 get the AX-TOYUSB or PAC USB-TY1.
Toyota 86 / Scion FRS:
JOYING Universal Wiring Harness for Toyota
https://www.amazon.com/JOYING-JY-C-T.../dp/B0152HE3RQ
note: Keeps steering wheel controls, you need separate ax-toy28swc harness to steal cables for AUX. alternative to hilux harness for those without backup camera. Joying only.
Metra Electronics AX-TOYCAM3 Backup Camera Retention 24-pin harness, contains yellow backup RCA
https://www.amazon.com/Metra-Electro.../dp/B01E4B6UQS
https://www.sonicelectronix.com/item...OYCAM3-6V.html
note: 24-pin harness with yellow RCA for backup camera for FRS and 86 cars. For '17+ BRZ get SUB28SWC-6V
Axxess AX-TOY28SWC Steering Wheel Controller Add-On Harness for Toyota Vehicles -- 28-pin harness connector WITHOUT backup camera RCA
https://www.amazon.com/Axxess-AX-TOY.../dp/B00BXF5A74
note: For cars without backup camera and with 28-pin connector.
PAC USB-TY1 Toyota USB retention adapter for 2013
https://www.amazon.com/PAC-USB-TY1-T...dp/B00F0YJ49O/
All FT86 cars:
Joying toyota Hilux harness, has 28-pin harness integrated
https://www.amazon.com/JOYING-JY-C-T...dp/B0152HEBWS/
note: could potentially get this instead of separate 28-pin connectors.
Retains steering wheel control and AUX input.
Does not have yellow RCA for 28-pin backup camera connection, but has yellow RCA on headunit side for Joying headunits. Need axxess sub28swc to steal yellow rca on harness side.
12V to 6V Converter, DROK Car Power Converter -- for backup camera
https://www.amazon.com/dp/B00CGQRIFG/
various harness types
https://www.autoharnesshouse.com/67122.html
note: these come wired for expensive unnecessary SWC interface modules. Probably not gonna get this. Get Joying hilux harness.
Tesa 51608, 25m x 19mm adhesive wiring cloth tape original ISOBAND 3 pcs
https://www.amazon.com/Tesa-adhesive.../dp/B00XPDVER2
note: cloth tape for wire loom management.
METRA 10 AND 6 PIN RADIO WIRING HARNESSES - mostly useless. Buy joying harness, or use the one that comes with your stereo.
http://www.ft86speedfactory.com/metr...-forester.html
Notes
1. Apparently, headunits with integrated amps/DSPs do not work with the twins. The twins have an external amp on the trunk on the driver's side. Factory amp needs an analogue signal while amped headunit outputs digital. Do not get a digitally amplified unit!! Confirmed by JstnBrdy
Turns out this is BS. "Integrated" DSP is software only. The hardware part is the SPDIF connection for digital output, but the DSP part can be enabled or disabled so you can output analog signal for factory AMP using the regular harness cables. Buy DSP unit without worries.
2. FRS and 86 cars use a separate 24-pin harness/connector for the backup camera, 2017+ BRZs use the 28-pin connector for the same thing. Steering wheel controls are also on these harnesses. Confirmed by itsAlex
3. 2016+ BRZ moved the AMP cable from 10+6 pin cables to the 28-pin connector, pin #9. Sigh. Lots of people running around without front door speakers working.
4. You can alternatively use a wiring interface to get SWC. Expensive, complicated, and a waste of money, but it works. Much better to use 28- or 24-pin adapter directly.
5. If you have speaker hum/hissing/high pitch noise, see Pumpkibbles' post. https://www.ft86club.com/forums/show...17&postcount=4
Thanks to:
Akuma147, nothing in this guide would be possible without his pioneering efforts.
Thriller for his incredibly clean and well organized knowledge base/DIY thread. you are a god.
Everyone else that chipped in with their setups, failures, success stories and contributions.
Old 01-24-2020, 12:24 AM   #4
staycrushing
staycrushing's Avatar
Drives: A Hot Mess
So I have a 2013 frs...
Got this head unit, plugged in harness and everything lights up but no sound.
Have the OEM audio plus system.
Any tips ? ��
one of the first people to ruin the frs.
staycrushing is offline   Reply With Quote
Old 01-24-2020, 12:56 AM   #5
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
I need more information. Did you solder the harness yourself, or you just took the harness out of the box and plugged it? Did you use this guide or one specific for FRS?
Finally, is the "OEM audio plus system" the infamous JDL audio system?
Old 01-31-2020, 08:38 PM   #6
staycrushing
Drives: A Hot Mess
I just plugged in the harness as it came.
Here is the site for the system
https://oemaudioplus.com/scion/frs/
Old 03-10-2020, 04:32 PM   #7
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Hey staycrushing! Sorry for the late response, I did not get a notification email for some reason. Were you able to fix your problem? Without knowing much else, I have a few theories that could help you.
Here are three things to think about: the Dasaita headunit has a built-in DSP, but it requires you to use the RCA inputs, so that rules that out. For our cars the headunit must use the amp located in the trunk. The factory amp is connected to the headunit through the factory harness, but you must modify the DASAITA harness to power the factory AMP in the car. In the FRS, the factory amp turn-on is on the 10-pin plug, pin 9. You need to wire the cable on pin 13 of the black dasaita connector to the previously mentioned wire on 10-pin plug.
For the BRZ, you must solder the pin 9 cable from 28-pin connector to pin 13 cable from black connector because amp pin is located differently. This is detailed in my guide, and was required so the big door speakers could work.
The biggest problem is you have no sound, which did not happen to me because only the door woofers are powered using the trunk AMP. The oem audio plus for FRS advertises plug and play harness with factory headunit, so it should theoretically work just fine with aftermarket unit, except for the modifications to DASAITA harness.
A local stereo expert should be able to help you I'm sure. Let me know if you ever fixed this problem!
edit: a few references
http://www.ft86club.com/forums/attac...4&d=1340370296
https://oemaudioplus.com/wp-content/...Q_Version2.pdf
Old 04-15-2020, 10:51 AM   #8
staycrushing
Drives: A Hot Mess
I found out what it was! The internal dsp was messing with the OEM audio plus system.
Now it works great !!
Old 04-15-2020, 03:28 PM   #9
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Fantastic, glad to hear you fixed it. Do check your two front door speakers to see if they are powered and working. Mine were not working, despite everything else working fine, due to factory amp not being powered by the HU.
Cheers
Old 10-05-2020, 10:42 AM   #10
shouk_1987
Drives: QQ
Thanks Guys for this lovely thread
Now if I may ask and apologies if the Question is not for the same ride as you are
I have a dasaita max6 unit with dsp as well but my car doesnot have any stock amplifier or subwoofer etc
I have only changed the 4 stock speakers and now wants to add a subwoofer which will require an external amplifier
I am aware that we have pin 13 at the big harness for the amplifier signal
But i also have another rca output called "sub"
Can anyone assist me in the connection from the headunit tobthe newly added amplifier and subwoofer that I will add
Thanks in advance guys
shouk_1987 is offline   Reply With Quote
Old 10-10-2020, 10:51 PM   #11
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Hey Shouk, I'm a bit confused. You said you don't have any stock amplifier, did you remove the stock one and/or added a new aftermarket amp? All cars come with a factory stock amp that powers the two speakers located in the doors. Pin 13 of the harness only powers the amp, not the "amp signal" (no such thing in the harness).
I'm not entirely sure how an aftermarket amp is wired. Does it power the door speakers? Then it would replace the factory one and be wired directly to the car wiring, plus powering the subwoofer and you would need to wire the subwoofer signal to the center console wire loom. Or possibly you would need to wire the aftermarket amp directly to the center console with RCA plugs at the end to connect to the headunit.
In my case I only had to power the factory amp using the headunit 12v, and only had to modify the Dasaita harness for this. You are going to have open a new thread and hope a car stereo expert to chime in or go to a car stereo board or simply go to a car stereo shop, the experts would know how to best approach it. Sorry I can't help more.
Old 10-21-2020, 08:13 PM   #12
ChazzDiss
Drives: Subaru 2014
This was, indeed, a very helpful thread. I may end up sharing this with my mates. Cheers!
ChazzDiss is offline   Reply With Quote
Old 10-23-2020, 01:30 AM   #13
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Thank you Chazz, if it helps even a single person it makes having written this whole dribble worth it.
Old 08-17-2021, 12:14 PM   #14
ymshulman
Drives: '17 BRZ
This is a great thread - I keep referencing it.
(n00b?) question: I purchased the Joying Hilux harness, and it only has a few pins on the 28-pin harness (for steering wheel controls and aux, I believe).
The wire to turn on the factory amp is a bare wire - it doesn't have the pin on the end of it, like the ones that are already inserted into the harness do. Is that something I can buy somewhere? (I'll also need some pins to wire in my factory reverse camera.)
ymshulman is offline   Reply With Quote
dasaita, harness, headunit
Installing a backup camera on a 2015 FRS? PacManTheRS1.0 Electronics | Audio | NAV | Infotainment 7 05-03-2018 11:04 AM
After installing backup camera, radio turns off randomly sometimes VeganGirl Electronics | Audio | NAV | Infotainment 6 02-26-2017 10:47 AM
My experience installing a backup camera ARTBRZ Electronics | Audio | NAV | Infotainment 0 03-19-2015 08:37 AM
Installing a Backup Camera on a Premium Bespoke Audio System Ornelas66 Electronics | Audio | NAV | Infotainment 3 03-04-2015 04:33 PM
Help installing backup camera / setting up AV on BeSpoke? l0aded Electronics | Audio | NAV | Infotainment 11 07-18-2013 08:05 PM
