Old 01-15-2017, 03:16 PM   #1
VeganGirl
Drives: Scion FR-S 2013
After installing backup camera, radio turns off randomly sometimes
Hi I got a backup camera installed yesterday, since then it has turned off twice what should I check?
This is the kit I bought:
http://www.autoharnesshouse.com/19867.html
VeganGirl is offline   Reply With Quote
Old 01-15-2017, 04:52 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
The first thing I would look for is a bad/loose/not tightened ground wire.
Old 01-15-2017, 09:38 PM   #3
Eman
Drives: 2013 Scion FR-S 10 series
Did you install it yourself or have a shop install it? If a shop did it, take it back and have them fix it. If you (or a friend) installed it I would pull the radio out and check for any loose connections in the back.
A little more detail would help. The radio turns off, the camera turns off? Does this happen right after the back up camera comes on/goes off? Randomly, what?
Eman is offline   Reply With Quote
Old 01-15-2017, 10:06 PM   #4
VeganGirl
Goes off randomly when driving. And then reboots . I'm gonna take it back the shop when I have them do my viper alarm in a few weeks
Old 01-16-2017, 09:19 PM   #5
Eman
That's what I would do.
Old 02-25-2017, 02:22 AM   #6
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
Did you find out what is causing it yet?
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 02-26-2017, 10:47 AM   #7
VeganGirl
Yes it had something to do with the way they plugged it in, they said it was lose, they reworked it and now it's perfect !
Paying for help installing items (Backup Camera, Mudflaps, Armrest) JGalp Southern California 3 03-19-2016 08:02 AM
Navi radio randomly turns off while driving Streetthrowback Issues | Warranty | Recalls / TSB 12 01-10-2016 07:40 PM
My experience installing a backup camera ARTBRZ Electronics | Audio | NAV | Infotainment 0 03-19-2015 08:37 AM
Installing a Backup Camera on a Premium Bespoke Audio System Ornelas66 Electronics | Audio | NAV | Infotainment 3 03-04-2015 04:33 PM
Help installing backup camera / setting up AV on BeSpoke? l0aded Electronics | Audio | NAV | Infotainment 11 07-18-2013 08:05 PM
