Old 05-02-2018, 04:51 PM   #1
PacManTheRS1.0
PacManTheRS1.0's Avatar
Drives: 2015 Scion FR-S Release Series 1.0
Installing a backup camera on a 2015 FRS?
Hey everyone! New to the forum and new owner of a RS1.0 here. I'm curious if anyone with a 2015 FRS has installed a back up camera and how hard it was to get it working if so?
Also if you don't mind linking where to buy it from that'd be great, thanks!
"I am not designed to come second or third. I am designed to win." - Ayrton Senna
PacManTheRS1.0 is offline   Reply With Quote
Old 05-02-2018, 05:30 PM   #2
Impureclient
Drives: 2015 FR-S
[ame="https://www.youtube.com/watch?v=daiDH2v4wUg"]How To Install Reverse Camera Into Toyota 86 Factory Screen - YouTube[/ame]
Impureclient is offline   Reply With Quote
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
PacManTheRS1.0 (05-02-2018), Spuds (05-02-2018)
Old 05-02-2018, 07:39 PM   #3
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
There is a ton of info out there. just search.
http://www.ft86club.com/forums/showp...ostcount=15618
http://www.ft86club.com/forums/showp...ostcount=15636
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
Old 05-02-2018, 07:43 PM   #4
Audio
Drives: 16 FR-S Raven
You should just trade in for a 2016 FR-S.
Audio is offline   Reply With Quote
Old 05-02-2018, 08:05 PM   #5
DarkSideFRS
Drives: 2013 pearl white FR-S
i'm getting mine installed this weekend for $100... can't be bothered with electronics lol
DarkSideFRS is offline   Reply With Quote
Old 05-02-2018, 08:09 PM   #6
PacManTheRS1.0
Ironically I searched for a 2016 Red FRS for months but could never find one that was close or had everything I wanted (Spoiler, Auto, 15k or lower miles)
Old 05-02-2018, 08:31 PM   #7
Audio
But It had a Backup Camera.
Old 05-03-2018, 12:04 PM   #8
RickyBobby
Drives: 2013 Firestorm FR-S AT
Again, do a search for backup camera in the Electronics | Audio | NAV | Infotainment section. Lots of info.
Here's my install: http://www.ft86club.com/forums/showp...5&postcount=20
If you find a camera that works with 6.0V then, if he still sells it, you can use SVXdc's wire harness. http://ae64.com/Rear-camera-install-16p-FR-S.htm
http://ae64.com/Rear-camera-16p-operation.htm
http://ae64.com/Rear-camera-16-pin.htm
Besides the wire harness the FR-S needs a reverse trigger wire. The BRZ does not.
I bought what I thought was a genuine Rydeen Duo from an ebay vendor, but it was a counterfeit. A genuine Rydeen will have a serial/model # sticker on it. Mine did not. So I had to go with the AutHardnessHouse's wire harness and trigger wire.
http://www.autoharnesshouse.com/19867.html
It's much easier to run the camera wire along the top of the trunk driver's side panel, diagonally under the rear left seat (remove the 10mm seat bolt and lift the seat up just enough to run the wire under it), and then tucked under the center console to the HU. No need to remove any panels except the lower panel on the driver's side to attach the trigger wire. I zip tied the excess wire to the amp wire and attached the camera ground wire to the one of the amp bolts.
RickyBobby is offline   Reply With Quote
After installing backup camera, radio turns off randomly sometimes VeganGirl Electronics | Audio | NAV | Infotainment 6 02-26-2017 11:47 AM
Paying for help installing items (Backup Camera, Mudflaps, Armrest) JGalp Southern California 3 03-19-2016 09:02 AM
My experience installing a backup camera ARTBRZ Electronics | Audio | NAV | Infotainment 0 03-19-2015 09:37 AM
Installing a Backup Camera on a Premium Bespoke Audio System Ornelas66 Electronics | Audio | NAV | Infotainment 3 03-04-2015 05:33 PM
Help installing backup camera / setting up AV on BeSpoke? l0aded Electronics | Audio | NAV | Infotainment 11 07-18-2013 09:05 PM
