Old 09-12-2019, 01:57 PM   #1
mauly
mauly's Avatar
Drives: 2016 BRZ Limited
ROM corrupt when opening in RR
I'm running an SBD500x kit, OFT sent me a base tune to use but they are taking months to respond so I'm attempting to edit my tune but I get an error when opening the tune file in RR and all the numbers are scrambled. My cal id is ZA1JF40D, I am using the F40D OFT definition also. Obviously im a noob and missing something here but any help would be appreciated!
It won't let me attach the file but the filename is:
OTS OFT350 Full exhaust B01D_F40D
Is it somehow hacked to appear as F40D?
mauly is offline   Reply With Quote
Old 09-12-2019, 05:37 PM   #2
steve99
Correct its likely your rom has calibration id hacks to allow oft to load a rom thtats not your native calid.
It woyld appear your rom is likely a B01D but calod hacked to look like an F40D.
So you would need a B01D definition to open it. However you would need to "hack" the B01D def to look like an F40D to fool romraider
Old 09-13-2019, 04:26 PM   #3
mauly
mauly's Avatar
Wayno's Definition tool tells me its an A00D hacked to an F40D, I've tried to hex edit a clean OFT A00D def but it leaves me with a few shoddy tables and numbers in random places, If you could help me make this work in RR i'll be more than glad to throw you a tip on paypal
attached the zipped tune file. SBD TURBO TUNE.zip
Old 09-13-2019, 06:14 PM   #4
steve99
attached the zipped tune file. Attachment 181214
Ok got a definition working. Yes its an old A00D rom. Those rom had a fult from factory with transient ignition retard not active id suggest you fix that as it can cause di injector issues if you do a lot of high rpm shifting.
Ive messaged you
turbo oft
Corrupt SD - blackvue dr650gw-2ch SmartedPanda Electronics | Audio | NAV | Infotainment 7 06-18-2016 10:57 PM
Need Help Opening Taillights in PDX XanRules Northwest 7 10-07-2015 05:07 PM
Ecutek Corrupt ECU, Bad Flash, Can i reset? gdrider77 Software Tuning 48 07-04-2014 12:25 AM
Trunk not opening grgonium Issues | Warranty | Recalls / TSB 4 02-06-2013 03:47 PM
