Old 02-06-2013, 02:08 PM   #1
grgonium
grgonium's Avatar
Drives: Whiteout FR-S
Trunk not opening
So went to the car today, and pushed my trunk release, but the trunk didn't pop open. Ok, so maybe something rolled in the trunk and pushed the button.
When I got to the trunk, put the key in, it didn't turn!
Anyone else have this problem?
Ended up having to reach through the back seats to find the release to fold the seats down, reached in with the snow brush to push the release button so I could open the trunk.
I thought there might be something blocking the latch, so when the trunk was open, I tried turning the key again, but it didn't turn.
Got the call in to dealer to check it out. Should be a warrenty issue.
grgonium is offline   Reply With Quote
Old 02-06-2013, 02:28 PM   #2
bakerr6
Drives: 2013 raven black fr-s
common problem, pull the seats down, pop the trunk open then go to the outside of the car.
on teh driver's side, there's a button you need to push to unlock it
bakerr6 is offline   Reply With Quote
Old 02-06-2013, 02:39 PM   #3
wheelhaus
wheelhaus's Avatar
How certain are you it was YOUR car you were trying to get into? j/k...
Was it only the trunk release you were having problems with? It could be the button itself (the one inside the driver's side trunk area, as bakerr6 mentioned), or it's wiring. When the button is set for the security feature (no open) the curcuit is open. So, if the wiring is bad it would make the ECU think it's in the security position, regardless of what position the button is in.
The normal (non-valet) key and fob should work regardless.
wheelhaus is offline   Reply With Quote
Old 02-06-2013, 03:43 PM   #4
grgonium
grgonium's Avatar
The issue was the key not turning. I didn't have the valet key with me. both the button beside the steering wheel, and the key fob didn't open the trunk, so I got into the trunk to push the "trunk release" button which disables those features. Once pushed, the trunk opened with both key and button in car. However the key didn't turn still.
So not the buttons themselves, but the key/lock.
Old 02-06-2013, 03:47 PM   #5
bakerr6
take to dealer and ahve them replace the key lock. There'sa mechanism in the lock itself that actuates once the key is placed in the slot
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 09:36 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Southern California 0 12-16-2012 02:46 AM
trunk opening it self Im_SPEED Issues | Warranty | Recalls / TSB 12 09-10-2012 10:49 PM
Trunk not opening FRomar-S Scion FR-S / Toyota 86 GT86 General Forum 11 08-16-2012 05:23 PM
