Old 09-10-2019, 11:07 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Does anyone know the length of the stock front sway end links?
I'm still fine tuning my adjustables, I think they might be much too short but I've since tossed the OEM ones and I'd like to compare.
Thanks
Spacemane969 is offline   Reply With Quote
Old 09-11-2019, 12:56 AM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
You cna tune the adjustable based off feel. That's why they are adjustable. If you want no preload on them then look at where the sway bar sits naturally and adjust out your endlinks to that. It should be relatively flat.
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Tristor (09-12-2019)
Old 09-12-2019, 02:30 PM   #3
Spacemane969
I don't get the "natural" position. When disconnected from both links, it has about 90 degrees of swivel from a vertical to horizontal position. Where do you start?
I adjusted quite a bit shorter, but it still feels tight. They felt like money when I first installed them..but then the suspension settled and they bound up.
Old 09-12-2019, 02:41 PM   #4
Code Monkey
Drives: Subaru BRZ
This may help:
[ame="https://www.youtube.com/watch?v=DT80zCBMUyc"]linky[/ame]
Code Monkey is offline   Reply With Quote
The Following 3 Users Say Thank You to Code Monkey For This Useful Post:
Clutch Dog (09-12-2019), Spacemane969 (09-13-2019), Tristor (09-12-2019)
Old 09-12-2019, 03:58 PM   #5
wparsons
wparsons's Avatar
At resting height you want the blades of the sway bar level with the ground. Adjust the end links so that it's level and no twisting force applied at resting height. Chances are high that they'll be different lengths side to side to keep any preload (twisting force) off the bar at resting height.
What do you mean by this? When are they bound up?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 09-12-2019, 05:37 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
front looks like 9" & 5/8ths from ball joint to ball joint. rear is 3" & 5/8ths
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
Hyper4mance2k (06-13-2024), MrSkubi (08-20-2023), Spacemane969 (09-13-2019)
Old 09-13-2019, 01:35 PM   #7
Spacemane969
Thank you so much.
Old 09-13-2019, 01:37 PM   #8
Spacemane969
Just a tightness in the front end in general. It feels like I'm always hanging on to the wheel for dear life on turns instead of being in control.
Old 09-13-2019, 01:40 PM   #9
wparsons
wparsons's Avatar
Just a tightness in the front end end general. It feels like I'm always hanging on to the wheel for dear life on turns instead of being in control.
You're looking at the wrong thing if you think the end link length is causing it... has the car always felt like that? If not, what did you change between it driving nicely and this?
flickr
Icecreamtruk (09-13-2019)
Old 09-16-2019, 03:19 PM   #10
Spacemane969
It's been this way ever since I put TRD springs on. I've added components here and there but nothing felt substantial until I added the endlinks. First drive felt perfect. It's the feeling of the suspension diving and planting itself in a turn, with little to no input from the wheel. The day after the install, that feeling was gone already. Note that I installed them with the hubs suspended in the air, which I later learned was incorrect.
Old 09-17-2019, 09:41 AM   #11
wparsons
wparsons's Avatar
Have you had it aligned yet? Removing the front shocks, plus lowering, is guaranteed to have the alignment out by a decent amount.
flickr
Leonardo (09-17-2019)
Old 09-17-2019, 02:28 PM   #12
Spacemane969
Yes multiple times. Installed adjustable rear LCAs and front camber bolts to bring everything back to factory spec. I even have bump steer correction kit.
Old 09-17-2019, 03:12 PM   #13
wparsons
wparsons's Avatar
What are the current alignment specs? Within spec can still be wildly out and drive funny.
What tires? How old?
If it's not that, I'd have a friend drive it, it sounds like it might be some sort of placebo.
flickr
Old 09-18-2019, 12:56 PM   #14
Spacemane969
Alignment is buttoned up really nicely, I make sure that it's better than factory but still within OEM ranges. I think about placebo alot, I might have to do a swap drive with something stock, but I know something just doesn't feel right.
I'm also still having creaking and clunking in the end links although it's not as severe ,as I've adjusted it after install. I've seen so many different opinions on install, some say that the lengths don't have to be equal left to right, some say they have to be absolutely perfect. I noticed the other day that somehow my right wheel measures up to 5/8" higher than my left wheel on completely flat ground(measured to fender). Not sure if that is acceptable or normal.
Nuts for Front Sway Bar End Links. oldlostcory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-27-2019 07:25 PM
ISO Front sway bar and end links vladniko86 Want-To-Buy Requests 0 05-30-2019 02:59 PM
WTB/ISO: stock front sway bar and end links 8RZ Want-To-Buy Requests 2 05-01-2017 03:55 AM
Front Sway bar end links rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-09-2015 11:33 PM
WTB: Whiteline Front sway bar Links. Filipino Royale Brakes, Suspension, Chassis 0 08-06-2014 02:46 AM
